Diff question
  • blueapplesoda
    • Dec 2005
    • 1904
    Diff question
    will any diff from any bmw work in e30s by swapping the rear cover? or am i mistaken.
  • MikeE30325i
    • 2356
    You Are Mistaken. There Are Small, Medium, And Large Cases. But Everyone I Hear Anything From Is Mixed, Some Say It Fits, But Others Say It Wont. I Am Not Too Sure
    • Brew
      • 3060
      Maybe you shouldn't post then.
      There are two "sizes" of diffs that will fit e30's. The "small" case diffs that came in 318s, and the "medium" case diffs that came in the I6 e30, the e30 M3, and e28s. Here's a decent link: http://www.e30eta.com/ecdiff.htm
      '91 318is
      • erik325i
        • Jan 2005
        • 3567
        no, you are mistaken. There are only certain cars that have e30 compatible diffs. You can use the diff from e30s, Z3s, 5-series [I think the e28], probably the 318ti, and I think even the e24 (this one may be wrong). You will need to swap the cover and output flanges in order to use most of these though.
        -Erik
        • blueapplesoda
          • Dec 2005
          • 1904
          sweet thanks
          • AdamF 88iS
            • 2051
            You can use small and medium case diffs from
            E24 (non-M)
            E28 (non-M)
            E30
            E36- TI or Z3 only.
            If you're tricky you can swap gear sets from E32s, E34s, E36s, and others... the guts are the same but the housings are totally different.
            Adam Fogg- '88 M3
            Common sense- It's the new 'gifted'
            • Rocla
              • 922
              E24 (non-M)
              E28 (non-M)
              E30
              E36- TI or Z3 only.
              and
              E34 very early m20 powered ones.
              E28, E24 and E34 have type 188(=medium= e30 "big") case and will require e30 drive flanges and back cover.
              I don't know about z's and ti's.
              Current:
              BMW 320i 2d 2.0 m20 -88
              BMW 325i Cabriolet 2.5 m50 -88
              BMW 316i touring 1.6 m40 -90
              BMW 320i 4d 2,2 m54 -01
              • crazynoll
                • Feb 2007
                • 54
                does anyone know if an 86 325e has LSD?
                <img src=http://www.r3vlimited.com/board/image.php?u=14143&dateline=1175417424&type=profile >
                • euro3
                  • Aug 2004
                  • 761
                  E28's
                  M30 powered E28's had the large type (210mm).
                  I'm pretty sure E34's have the large as well.
                  And, since E24's were powered by M30 I'm guessing they also have the large case
                  • AdamF 88iS
                    • 2051
                    Originally posted by Rocla
                    and
                    E34s don't used the same case. If you're talking strictly 188 gear sets, then you can use damn near any BMW diff.
                    Adam Fogg- '88 M3
                    • joshh
                      • Aug 2004
                      • 6195
                      It was a factory option. If the casing has a white painted "S" on it then yes....or the tag has an S then the gearing numbers for the diff.
                      "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
                      ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
                      • crazynoll
                        • Feb 2007
                        • 54
                        ok thanks
                        • Mr.SWISS
                          • Nov 2005
                          • 1251
                          So the e28 535is diff will NOT work?
                          Originally posted by 325Projectz
                          don't listen to the diagram... listen to mr. swiss.
                          :nice:
                          • AdamF 88iS
                            • 2051
                            Have to swap the rear cover and output flanges. The main case is the same though.
                            Adam Fogg- '88 M3
                              • 34844
                              how about the M couple and MZ3 roadster? I know the cover works but I have no idea on the diff.
