How much power can the m10 5spd take ?
  • Jean
    • 18228
    How much power can the early e30 318i transmission take before breaking ?
    I've seen stock m10 engines handle 200-300hp, but is the transmission able to handle this power for a long time ? I've had a clutch job done on mine recently, about 1k miles ago, flywheel was also resurfaced and new master/slave cylinders were installed along with new tranny ie bushings.
    Now I am considering going the m10 turbo route, plus it would be kind of a waste to throw away the tranny after I spend close to $800 on the clutch parts/labor etc. Would I be safe running 200-250whp through it with regular autox/track days ?
    So, back to the main question, how strong is the tranny ?
  • FredK
    • 14763
    I believe the number touted around the interweb is that the Getrag 240 can handle around ~220 lbs-ft. The clutch, however, probably can't.
    • Jean
      • 18228
      And of course there is no other tranny that bolts to the m10 to handle more ?
      • asubimmer
        • 6482
        it can handle 240lbs of tq...
        at least thats what its rated for
        • backtrail69
          • Jul 2005
          • 4471
          You could bolt up a getrag 265 or 280 if you wanted. They are expensive though.
          :: PNW Crew ::
          '87 325 4dr, '74 2002
          • asubimmer
            • 6482
            yeah the s14/265 will bolt up. But good luck finding one and good luck not spending a TON of $$. Not worth it for a 25lbs increase imho.
            • Borat
              • Jan 2005
              • 494
              Whats the code for the M30 'box, has that been mentioned? Haven't done myself but apparently fits, may to make a few clearanc dents on the transmission tunnel or something like that though.
              • gstuning
                • 833
                You can put alot more then 240lbs
                The Getrag numbers are not there torque design outputs,
                you think the M30 trans was designed for 265LBS ?
                When the FI guys put twice as much trough them.
                Those are just internet rumours
                Gunni
                @ Prodrive / Aston Martin Racing
                • asubimmer
                  • 6482
                  thats what they are rated at, or so I've been told from a MUCH more reliable resource than someone on a forum in iceland. How is that a hard concept to grasp anyway? The 318 is 1.8l the 325 is 2.5l the getrag 240 is rated at 240lbs of tq.
