Will the shifter from a 91 318i tranny work on a 90 325is tranny? I don't see the shifter on RealOEM. Thanks
Will shifter from 91 318i tranny work on 90 325is tranny?
I see... Can the shifter be removed from the tranny without removing the tranny? I can convert my auto console to fit the manual tranny, boot, shifter, correct?Comment
by console I meant what is seen from the inside of the car. The window switch, shifter, ashtray piece. Will everything I need to mount the manual transmission be there in my auto already or are you saying I will need a some other "rear mount"?Comment
