I'll try and get up pics tonight of one or two of my swaps for you crybabies .
5 speed wiring probs
Ok I was able to take one pic of my latest swap .
First pic is nice and clear as it during the day ...but just shows the wires and what they are .
Dos not show where they go so the 2nd pic shows that and it was taken tonight .
This is just a temporary jumper wires et-up right now as I just finished this car and have not finised the wiring and have not added the cruise feature .
Oh and just image that the 2 blue wires on the bottom are the factory blue/white and green/white that come from the reverse light switch . :D
Just so you know where shit is coming from and what it should look like .
Now here is all you need to do :
I've found that it easier and cleaner to leave in all of the wiring and harness plugs as is and just add the jumper , I usually rewire the other side of the plug from the auto lever .
Good luck .
hmm... now i have a cracker of a q for u all. The cable i found that no1 has any idea about. well i pulled the cabling around it off and found its cables same thickness as the other wires. One is purple and one is brown when i touch the purple one to the green/black green/yellow line a whirring noise occours in the back of my car pretty sure fuel pump. So wat the hell is that cable if it bridges to the fuel pump? o and also no reverse lights still argh
