pedal box question
  • Tavern Gnome
    • 2137
    pedal box question
    I'm about to do a 5sp swap in my 88 325i vert. Does anyone know if I am going to have to use a 5sp pedal box or will the clutch and brake pedals mount to my pedal box? Thanks,
    Ryan
    __________________
    1987 Toyota Landcruiser V8
  • AndrewBird
    The Mad Scientist
    • 11898
    I think you need the whole pedal assemble, including the box. I don't think the auto box has a place for the clutch pedal. I might be wrong though. Take a look under the dash and see.
      I think the pedal box is the same for both variants. The auto just doesn't have the clutch bits installed.
      • FredK
        • 14764
        The pedal box is mostly the same. However there is an additional metal plate on the left side of the manual pedal box for non-airbag cars where the return spring for the clutch arm sits.
        • Tavern Gnome
          • 2137
          So can mine work? Do you NEED the metal plate? Thanks guys,
          Ryan
          __________________
          • Teaguer
            • Sep 2004
            • 6167
            Fred is right but you can do without that style of return spring .
            You can just add the clutch pedal and swap the brake pedal over .
            Just add a return spring to the clutch arm and have the other end hook onto the support that runs up under the dash .
            I may be making it sound more confusing than it is ....if you need ai can post pics by tonight .
            • Tavern Gnome
              • 2137
              If you could post a pic that would help a bunch! Teaguer you need to write a book. I appreciate it.
              __________________
              • NABR 1337
                • Aug 2007
                • 73
                I am guessing that you are saying that you just need to find a solid mounting point for the return spring. A support would be the best choice. Or make a bracket to attach the spring to.
