86 eta tranny swap
  • kman_e30
    • May 2007
    • 573
    86 eta tranny swap
    about how much am i looking at to swap an auto to 5speed tranny?
    84 318i drift car
    04 mk4 gti 1.8t
    96 e320
    63 plymouth valiant
  • Sean
    • 5793
    I hate to say it, but you should really try searching. COulda sworn I saw a BRAND NEW thread on this like 3 days ago.
    However, you're lookin at $600-$1200 depending on where and how much you get parts for.
    - Sean Hayes
      • 37833
      If you're looking for a shop to do it, call these guys...
      I know it's an hour away but the quality of work is worth it.
      Grover Beach, California
      BimmerHeads.com
      • jeer
        • Sep 2007
        • 32
        Just did an auto to manual swap on my 325is just four weeks ago.
        It takes a manual tranny drive shaft, pedal assebly with clutch master with line to connect to clutch slave, flywheel, pilot bearing, maybe new brake fluid resevior with open tab to clutch master, jumping connector pins for the park neutral saftey switch and an inline switch if you want your cruise to work(wont work if it thinks the car is in park/neutral), and the trans cross member with hardware. not to mention manual trans with clutch and flywheel.
        thats pretty much it if i didn't leave anything out.:D
