3k miles = shredded guibo caused by tranny mounts
  • rcko
    • Mar 2007
    • 295
    well, here is a bit of advice when using aftermarket tranny mounts with aluminum cups... make sure their height match the OEM ones or your tanny will sit tilted up if the mounts are too long or tilt down if too short.
    The above with too tall of a mount caused my tranny to sit tilted upward and this caused the drive shaft to sit misaligned and to bend the guibo web back and forth with every revolution until it shredded.
    The fix was to compare OEM mounts with the aftermarket ones and use spacers between the chassis and the tranny cross brace to lower the tranny and have it sit even as with OEM mounts.
    I also reinstalled the drive shaft dampner since these offers some support to the guibo webs as well.
    - 0.05s and 0.1s FTW!!!
  • DaN
    • 1265
    thanks for the tip.
    How is the centering sleeve at the tip of your d/s at the guibo?
    If this is bad It allows the shaft to spin off center.
    • rcko
      • Mar 2007
      • 295
      I had replaced all three components, guibo, CSB and centering sleeve back when I did the engine swap 3k miles or so ago. After pulling the driveshaft this wknd to fix the guibo and shim the tranny mounts, I inspected the centering sleeve and it was still good. The little seal inside of it was still round at ~14mm and the offset from the edge of the shaft was ~5mm so it was good. It is incredible how little things like OEM mount height can cause so much damage in just 3k miles.
      • Jordan
        • 12916
        You did not notice the deflection in the disc when you installed everything?
        https://mtechniqueabs.com/
        • rcko
          • Mar 2007
          • 295
          after spending 10hrs wrenching swapping a motor and it is 2:30 am using a flourecent lamp for light it kinda escaped me that the thing was deflecting. but yeah... lesson learned.
          • BLAZEDe30
            • 6
            thx for the info guys....i just replaced the guibo, center bearing, and dropped in the p.urathrane tranny mounts....i got all the parts from Ireland Engineering since they're local.....i also used their p.urathrane motor mounts and rear subframe bushings.......
            next time im under the car, i'll make sure to check the tranny mounts height....i wouldnt want to do everything again anytime soon.......
            1989 325i --------- 170K mi.
            1995 740iL--------- 227K mi.
            1986 190e 2.3-16v - 90K mi.
            Don't Forget to Tip the Guy Changing Your Tires !!!
