I have the worlds sloppist shifter... what should I do?
  • scobaru
    • Nov 2007
    • 396
    1st I think I'm going to change out the shifter along with the bushings... I'm pretty new to e30's so I'm not really even sure where I should go about doing any of this...
    i'm thinking of going with a Z3 2.8 shifter but for bushings I'm not sure what bushings to get.
    currently 2nd gear feels like it doesn't really wanna go in or stay in and most of the gears the shifter has like 3-4 inches of play side to side.
  • soviet1942
    • 237
    Mine does too, mine does too. :(
    I need monies
    • scobaru
      • Nov 2007
      • 396
      http://cgi.ebay.com/ebaymotors/RACIN...em230213287837
      is there any feedback on ebay shifters? this includes a bushing too! I'm not sure waht all bushings are needed
      • Erick
        Official R3V Drifter
        • 11169
        http://www.r3vlimited.com/board/showthread.php?t=96596 ;)
        In all honesty and sales pitch aside, that eBay shifter looks like garbage. The only bushing you see is something that comes already with a factory shifter. Also, if your other bushings are bad on the other end of the selector rod, that shifter will do little good.
        ..::Support FullOpp::..
        FullOpp Stickers for sale!
        Feedback Thread
        • scobaru
          • Nov 2007
          • 396
          so is that 92.50 shipped? and are those all the bushings for the shifter?
          • Erick
            • 11169
            Yessir.
            Feedback Thread
            • scobaru
              • Nov 2007
              • 396
              cool so if theres any major slop in the shifter than I just have a shitty trans? lol
              • DaveSmed
                • Apr 2007
                • 1407
                Ehh, theres usually a few culprits that cause a sloppy shifter, and the shifter and cup bushing arent typically it.
                http://www.realoem.com/bmw/showparts...74&hg=25&fg=05
                Go for a # 11, 13, 14, 15, 19, and maybe 18 I forget.
                Get #2 in Delrin from the aftermarket supplier of your choice and let me know how your shifter feels.
                If you do put in a Z4 or Z3 shifter, might as well throw in a #6 while your in there.
                I have the Z3M in my car. I broke it already though.
                -Dave
                2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                Need some help figuring out the ETM?
                • scobaru
                  • Nov 2007
                  • 396
                  bump how do I take out 13,11,and 19?
                  • Skoobeesnak
                    • Jun 2006
                    • 132
                    Remove the clip 17 and slide the shift linkage out. Then you slide the clip 18, off of the machined part of 13, then drive the pin 17 out. Once you get there it is fairly easy to see what you need to do.
                    The hassle is getting to these parts. If I didn't have a seal leak from my transmission I wouldn't have ever bothered but once I did replace 13 it made my shifter a whole lot tighter.
                    • scobaru
                      • Nov 2007
                      • 396
                      yah it looks like I need to replace the seal too. wooo more money the car needs...
                      • DaveSmed
                        • Apr 2007
                        • 1407
                        Worth noting that 11 isn't the bushing in the base of the shifter, thats a permanent part of the shifter assembly. They are actually little washers which are real good at disappearing forever. If you buy new ones, there's a good chance you won't remember removing something like that.
                        -Dave
                        • DaveSmed
                          • Apr 2007
                          • 1407
                          Yep, 13 is the culprit in most cases i'd venture. I was in there for the same reason, seal leaking all over. Lucky me some tard siliconed the old seal in. I go to remove it and install the new one and the new one just drops right in with little resistance. :curse: Damn thing leaks to this day, and for the forseeable future.
                          -Dave
