parts lilst for tranny
  • viali8
    • Nov 2005
    • 673
    In the near future I am planning in replacing my 5-speed for another 5-speed. I have never done this before and want to know what parts i should replace (including seals) when the transmission is off. Also the car has a slight oil leak, would that be the rear main seal?
    Parts List
    1.) clutch Kit
    2.) pilot bearing
    3.) Throw-out bearing
    4.) rear main seal?
    What size torx sockets do i need?
    Any other special tools?
    i read in the bentley that MICRO LUBE GL 261 needs to be used in the input shaft for reinstallation? Where can i get this?
    Any help is appreciated. thanks Matt
  • E30Driv3R
    • May 2004
    • 1169
    i believe it is a 10 and a 12 torx
    Dan Zickel
    1995 M3, 1991 318iS, 1987 325iS
    • nefarious7907
      • Jan 2005
      • 1170
      output shaft seal, input shaft seal, selector rod seal.
      http://www.cardomain.com/ride/657387
      • duodvlhntr
        • Mar 2007
        • 111
        LOTS OF PATIENCE! Small hands help as well. Lots of extensions. Mostly patience.
        Been over a year and it still doesn't the other motor mount made...
        • duodvlhntr
          • Mar 2007
          • 111
          Oh, and you don't really need the input shaft grease. Just think about it. Clutch disc, liquid... not a good combo...
          • viali8
            • Nov 2005
            • 673
            cool... any other helpful hints?
