How hard it is ??
  • Patosdream
    • Mar 2008
    • 88
    How hard it is ??
    So has anybody here changed out their center bearing and flex disc before need some pointers to take on this task
  • e30_kid89
    • Apr 2006
    • 489
    Its pretty straight forward...it takes about 25-30 min for me to get the drive shaft unbolted and out not including the time it takes to get set up. Search r3v and online and you can gain tips/pointers here and there. GL
    • Patosdream
      • Mar 2008
      • 88
      thx kid
      • Dave
        E30 RAT
        • 11675
        USE THE DAMN SEARCH FEATURE NEXT TlME BEFORE YOU POST A QUESTION LiKE THlS!
        Current Cars
        2014 M235i
        2009 R56 Cooper S
        1998 M3
        1997 M3
        • Patosdream
          • Mar 2008
          • 88
          • Patosdream
            • Mar 2008
            • 88
            hey goofy theirs no DIY on this subject in the search engine ok that's why I ask !!!!
            • Lodsin
              • Sep 2006
              • 734
              Hey "pal" I'm pretty much retarded when it comes to figuring out how to get car shit apart. If I werent so weak the exhaust coming off would be quite easy and I could do this real fast. Just search around.
              • Patosdream
                • Mar 2008
                • 88
                thx shorty
                • atomic
                  • Jun 2007
                  • 5691
                  Invest in a Bentley manual, seriously best investment for your e30 period.
                  • JasonC
                    Site Manager
                    • 14451
                    1992 BMW 325iC
                    1978 Chevrolet Monte Carlo
                    • Patosdream
                      • Mar 2008
                      • 88
                      Jason thx that will help alot and Atomic I do have a bentley just wanted to hear it from someone else if it was hard to replace cause the oil pan and rack wasn't that smooth to change out
                      • BBY1104
                        Unbolt the bolts you can get to on drive shaft, rotate and get other bolts. Makes sure you remove the heat shield cause it made it a lot easier for me when I did mine on my old car. Then go from the differential side and do the same and rotate if needed. Leave car in neutral when you jack it up. I would recomend taking the driveshaft to a shop because you dont want to put it back together and have it misaligned. They will guarentee fitment upon re-installation.
                        GL
                        • parkerbink
                          • Jun 2004
                          • 10134
                          I can see how you missed that. It's only been there for three years.
                          Ask stupid questions get told to search, give an old timer an attidude be prepared for a flaming.
                          Can't take it?
                          e30tech.
                          • drift
                            • 566
                            IF you know there's a DIY ,
                            Why bother flaming, replying, wasting the bandwith and your time ?
                            I would just answer another question efficiently ;)
                            http://www.kingofeurope.net/2010/
