Help removing torque converter
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    When I pulled the tranny, the torque converter stayed on the engine. According to the Bentley, it is not attached to the flywheel and it should just slip off. But it's not budging a mm, so I'm wondering if maybe the Bentely is wrong? Or am I missing something? Any help is appreciated.
  • James Crivellone
    Head Janitor
    • 6305
    3 bolts hold the converter onto the flex plate.
    • CorvallisBMW
      • 13039
      already got those off...
      • dvmotorsports
        • Apr 2008
        • 658
        not that this helps, but i recommend a 5 spd swap.
        after what you have done, i believe that it should just slide off. penetrating oil is your friend.
        Originally posted by jrhaile
        For the record I have never fucked a goat.
        • CorvallisBMW
          • 13039
          5-speed swap is the whole reason I'm pulling the torque converter in the first place
          • devonjordan
            • Jul 2006
            • 2386
            Kill the dam thing haha, I'm still working on a shipping quote for that pan, sorry its taking so long.
            Hemingway said it best. “There are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.”
            Help a brother out, buy your detailing products here...
            • Mossman
              • Apr 2006
              • 1961
              pry bar between the flywheel and converter. Since it never has to work again you shouldn't have a problem applying enough force to get anything off. The nipple thing can rust and get stuck in there a little bit. Are you sure you got all 3 of those bolts off.
              • browntown
                • Jun 2004
                • 3524
                I have no idea what's involved, but sounds like a job for the BFH. The biggest sledge I've been able to buy in a short handle is 4 lbs. I'm tempted to buy an eight pounder and cut the handle in half.
                • CorvallisBMW
                  • 13039
                  Finally got it off. lots of prying with a giant crowbar, little bits at a time while my dad turned the crank from the front of the engine. Fuck that thing, it was on there tight.
