Halfshafts... have you ever replaced them?
  • kylebes1
    • May 2004
    • 2804
    I have had 5 e30s and the most recent on is the only one I have seen with damaged boots on the outer CV joint of the rear half shafts.
    Have you ever replaced yours?
  • backtrail69
    • Jul 2005
    • 4471
    Nope, but really should soon.
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • mattdk318i
      • Jun 2006
      • 3953
      i found out recently from eli that new ones can be had at O'reillys for 60$ plus core of coarse.
      That beats the shit out of having to replace the boots
      • erik325i
        • Jan 2005
        • 3567
        Yes, I've replaced a few.
        I would rather run a used halfshaft, than a cheap new one.
        I bought a cheapy one for my M3 one time simply because it's hard to resist a brand new halfshaft for under $100. When it arrived, the CV joints were already binding up and did not have free rotation. I took it apart and saw that it had almost no grease in it. I rebuilt it, and packed it will a lot of new grease. After a few weeks of rolling the car in and out of the shop (the car didn't run yet), it completely came apart. I ended up just buying a used one from a member of this forum.
        Also, the bearings in the aftermarket CV joints were smaller than stock.
        So, if anyone wants a shitty aftermarket zero mile halfshaft, I might still have mine.
        Erik
        • mattdk318i
          • Jun 2006
          • 3953
          Erik
          thanks for the info.
          • kylebes1
            • May 2004
            • 2804
            I want to slide a refreshed subframe in, with the 3.73 and maybe five lugs... Maybe I will just find some nice used ones.
            • matt
              • 3731
              They are easy as long as your wheel bearings aren't toast.
              It's one of those "ounce of prevention vs pound of cure" things.
              • kylebes1
                • May 2004
                • 2804
                O they are a million times easier than the bearing which i just replaced, but i fubar'ed the parking brake on the passenger's side and it is afro-engineered right now...
                • GotCone?
                  • Jan 2008
                  • 589
                  halfshafts... Have you ever replaced them?
                  yes!
                  Build : Das Drehmoment Ungeheuer
                  • BMWDriver
                    • Jul 2008
                    • 85
                    did one tonight took about an hour
                    • Danny
                      • 14217
                      I sold them before.
