hairline at the bottom
my rear main seal is teh leaky
I ask because I've been hearing a clunk mostly with lift off/on the accel in gear, and "rough"/lazy shifting. Sounding from the rear of the car. I figured it was the guibo, but it doesn't look that bad. Would a bad u joint (at the diff side) of the drive shaft cause this "clunking" I hear?
I also need to change my rtabs and subframe bushings.
