leaking from the top, tranny manual
  • Rockinlittle325i
    • 341
    so my tranny is leaking from the top, what are possible reasons?
    oo ya near the shift linkage I think
    You have Honda = I talk shit
  • drift
    • 566
    Might be a leaky detent cover seal.
    http://www.kingofeurope.net/2010/
    • Rockinlittle325i
      • 341
      what would cause that? how should I fix it? cost?
      • drift
        • 566
        It probably costs less than $10, and shouldn't be hard to get it done.
        • Rockinlittle325i
          • 341
          do I need to remove the transmission? (dumb question I know)
          just so I know, how does said cover work, what is it's perpose?
          • kenika65
            • Aug 2007
            • 1336
            Click on my 91is m42 link and there is a how to on replacing transmission seals.
            Your selector rod seal is leaking!
            1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
            1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
            • Rockinlittle325i
              • 341
              do I need to take the transmission out? how much would that cost to replace, is it the same for your 318 and my 325?
              • drift
                • 566
                Get all the parts needed, and then Preferably to remove the exhaust, disconnect the driveline / flex disc, be ready to safely support the tranny with a jack stand, undo the tranny mounts to lower it down to gain some space, and carefully extract the seals ( pics above), drive the new seals in place.
