Somewhere in the clutch line I'm leaking fluid. It's dripping a bit on the carpet (very little); however, there is often a drop waiting to fall at the point where the CMC connects to the firewall. Not only this, but also its dripping from the area where the control arm bushings are every time I come to a stop. I took a peek under the car and the metal line from the CMC to the rubber slave hose is more or less soaked in brake fluid.
I have no idea where this leak is coming from! My clutch isn't spongy, doesn't stick--shifts great! I just hope it isn't one of those lines from the reservoir to the cmc... They look like a pain.
