Leaky nipples??
  • DRTSRFR
    • May 2008
    • 1836
    Leaky nipples??
    I just swapped out my clutch and M/C.
    My brake light came on last night on the way home from work. I did a little digging and found the nipple and hose on top of the clutch M/C is touching the clutch return spring. When I actuate the clutch the spring rubs on the fitting and is causing it to leak.
    The nipple is pointing toward the left front of the car. Is that the correct orientation? I tried swiveling it to different positions with no luck.
    Which way do your nipples point?;)
    Thanks!
    Suspension tips here...
    http://www.r3vlimited.com/board/album.php?albumid=757
  • Aptyp
    • 6584
    thought you were lactating, got excited
    • Aptyp
      • 6584
      do you mean bleed screw? mine point down and toward the rear, not sure how it can be installed to point any other way.
      • DRTSRFR
        • May 2008
        • 1836
        No, the little black plastic elbow that is pressed into the top of the
        Clutch M/C and is fed via the resevoir.
        • Aptyp
          • 6584
          Ah, mine points toward the hose, toward fire wall. That thing can be rotated, but if it's old it will break.
          • DRTSRFR
            • May 2008
            • 1836
            My damn return spring is trying to rip the hose and nipple out of the M/C.
            I thought my clutch install was FUBAR'd 'cause my pedal wasn't returning as it had before the swap, but it was the spring hitting the fitting. I can push on the pedal and see the nipple wiggle...yea I said nipple wiggle.
            • Knockenwelle
              • Jul 2008
              • 395
              If you break the nipple, BMA DOES sell a replacement...
              Mike
              '91 325i track car. Mostly...
              • DRTSRFR
                • May 2008
                • 1836
                Thanks...already on order.
                But I've got to fix the issue or the new on will have the same problem.
                • mattdk318i
                  • Jun 2006
                  • 3953
                  this thread title makes me lol
                  • DRTSRFR
                    • May 2008
                    • 1836
                    Yea, I gues I'd rather have a leaky nipple that a crusty guibo...;)
                    • DRTSRFR
                      • May 2008
                      • 1836
                      ...Figured it out.
                      The return spring is not attached to anyting in the rear and had popped out of the groove it was supposed to sit in allowing the back of the spring to lay on the nipple and hose. I pulled the assembly out and no more leak!
                      Now it feels like a real mans clutch
                      Honestly, it feels like a clutch should feel. Who needs that little helper...?
                      • NC325iC
                        • Mar 2004
                        • 6565
                        i like the extra resistance
                        • Stephen
                          Шлем ишака
                          • 10774
                          I have nipples, Can you milk me?
                          Sorry in advance
