fuck my life.. x10
  • loonibab325i
    • Dec 2005
    • 770
    fuck my life.. x10
    So.. I was basically doing a s52 swap into an e30, and i didn't have time to do the clutch, so i had the motor sent to a shop, I used a spec stage 3 6 puck clutch.. anyway, after 1 MONTH of waiting, i finally get my damn motor back... and a couple months later my motor swap is complete.. I go to drive the car for the first time, but when i press the clutch in i hear a shit tun of spinning grinding noises.. so i had the car shipped to the shop again, after 3 weeks, i get the car back, and they say it's fixed blah blah(they installed the clutch disc backwards the first time..).. so from there I sent it straight to the exhaust shop... from the exhaust shop I drive it and right away i noticed something wasn't right with the transmission/clutch setup.. so anyway.. this is what my problem is now, maybe you all can help...
    When the car is idling, and i give it a little rev, say only a couple hundred rpms the trans starts chattering, but when i have the clutch pedal pressed down, it does not do this.
    Also, when i drive first to second gear, or reverse, it also chatters, but much louder, it makes some kind of clunking noise too, which isn't good at all..
    Also, when I turn the car off, I hear a shit tun of chattering from the transmission, like, a really gross clunk and chatter combined, but it doesn't do this if i turn the car off with clutch pedal engaged..
    i'm thinking it's a throw out bearing.. but the shop should have installed the throwout bearing... so uh.. help me, please!
    -Abe.
    s52 0-150mph & more http://www.youtube.com/loonibab325i
  • e30s52
    • Oct 2007
    • 5235
    do you get any vibrations when you rev it in neutral? and in gear till about 3000 then stops vibrating? thats what mine is doing and the stupid ass selector rod rubbing.
    www.gutenparts.com
    • golde30
      • 11464
      oh man, i had my clutch disk installed backwards the first time, it locked the tranny on, had to break aparts the bell housing into little pieces and take off the pressure plate to get the tranny off. sooo.... your tranny could be fubar from them yanking hella hard to get the tranny off, or it could be as simple as the TO bearing. are you running a getrag260? or an e36 tranny?
      IG: @Baye30
      • bataangpinoy
        • Jul 2008
        • 1636
        which way is backwards...
        do you want the springs in the clutch to face the pressure plate?
        My feedback:
        http://www.r3vlimited.com/board/showthread.php?t=186328
        http://e30tech.com/forum/showthread.php?t=74911
        Instagram:
        @gears_n_glory
        @functionmotorsports
        • Justin B
          Sikky Nar Nar
          • Mar 2005
          • 4273
          The plate usually will have some words on it that you can figure out what they mean. On my Sachs stock clutch it said getriebeseite, gearbox side.
          • PiercedE30
            • Apr 2005
            • 4220
            This is what happens when you don't know how to work on your own shit.
            My 2.9L Build!
            • golde30
              • 11464
              truth.
              IG: @Baye30
              • 416stroker
                • May 2008
                • 2448
                what trans are you running ? you got the right pilot brearing? it might be the trow-out.
                it could be a bad spring or somthing on the clutch disk.
                84 318I Delphin RIP
                87 325IS delphin 24v Sold
                89 325 Alpineweiss
                • loonibab325i
                  • Dec 2005
                  • 770
                  I'm running the ZF tranny of an 97 m3, and no.. no vibrations while in gear or anything like that.. just some weird as clunking as soon as u put it in gear.
                  And this is what happens when people don't know how to READ.
                  I said i took the setup to the shop due to time issues, i was doing a FULL 5 lug conversion swap at the time, as well as the motor swap while going to school full time, so i figured to help me out time wise i would do the suspension/brake and 5 lug conversion while the shop installs the clutch.
                  The clutch disc was installed backwards, I noticed the stamp that said "FW SIDE" facing the rear while the guy was trying to tell me the clutch is rubbing because i gave them the wrong one... i quickly corrected them.
                  • e30s52
                    • Oct 2007
                    • 5235
                    did you fix your shifter? if you did what did you do?
                    thanks alex
                    www.gutenparts.com
                    • loonibab325i
                      • Dec 2005
                      • 770
                      haha, no man.. my shifter can suck a nut right now.. i have more shit to worry about then it barly grinding on my dirveshaft lol i'm still curious to know WHY it freaking does that.. i'm sure it's an easy fix, just need to make some damn time for it!
                        If you used a lightweight flywheel, chatter from the transmission when in neutral with the clutch engaged is normal and to be expected. I can't tell if that's what's happening here, or if there might be other problems. But flywheel induced chatter might be part of what you hear.
                        • loonibab325i
                          • Dec 2005
                          • 770
                          Nope, no LTW flywheel. :(
                          • e30polak
                            • 6136
                            X2, even though it doesn't help your problem.
                            I have a gnarly throw out bearing noise, along with the flywheel chatter...sounds like shit. :x
                            INSTAGRAM: @UNDR8D_EMPIRE
                            • jahnaboi
                              • Oct 2006
                              • 1742
                              And here I thought all of you had a gravy setup. =P You said you have a clunking noise putting into first correct? Could be the differential. I also installed the clutch disk in reverse, but to my avail it didn't mess up anything just a loud screeching noise. I've done many clutch jobs before but what lead to my incorrectly installed clutch disk was my inexperience with dual mass flywheels (which is what we all have hence why we installed them incorrectly thinking it was correct).
                              SINdelle:E36 M3 5-Lug | 17x8 & 17x9 BBS RS | S52/ZF | 2.93LSD/3.5HFM/24lb Injectors/C&S Chip[B]SOLD[B]
