So, not knowing this, caused alot of headaches.
Short summary, I bought the car already slightly modified. Specifically, a short shifter already installed.
Fast forward. I needed my driveshaft rebuilt. I sent mine out, received one back with this huge ring (the vibration damper).
After getting everything installed, and take it for a drive, i'm getting some rubbing in 2nd and 4th gear.
I do alot of searching and come to find out this is common and either need to remove the damper or bend the selector rod.
I am choosing to remove the damper.
My question is, after i press out the studs that mount the damper to the d/s, do i just replace it with the same nuts/bolts that are used to mount the Guibo to the output flange? M10 x 50 Grade 10.9?
Some say to reuse these studs, and others just use nuts and bolts. Nuts and bolt sound better to me.
Thanks for the help/tips.
**for reference, removing #3 http://www.realoem.com/bmw/showparts...22&hg=26&fg=10
