what is the difference between the manual transmissions from a 325i from 86-88 than a 325i from 89-91?
what is the difference between..
the early transmissions 86-87 if not 85-87 have open ports for crank position sensor and another sensor, there is also some talk of different distance from slave cylinder to the mounting face in the oldest of these transmissions
but if you get one with the sensors just chop off the wires and leave them in there (if you have a late model)
also difference in output flanges, but these are fairly easy to change.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.
Originally posted by NC325iC View Postthe early transmissions 86-87 if not 85-87 have open ports for crank position sensor and another sensor, there is also some talk of different distance from slave cylinder to the mounting face in the oldest of these transmissions.The car makes it possible, but the driver makes it happen.
