Been months - Selector rod position
  • Mastrcruse
    • Sep 2005
    • 5340
    Its been months since I messed with the shifter mechanism and I can’t remember how the selector piece goes in. I have a short end and a long end. I have a bend in the middle.
    Does the bend face up or face down? Which end is short and which is long?
  • Mastrcruse
    • Sep 2005
    • 5340
    Then this will drop in (with the other pieces of course) like this? Bend making it bend to the back, right?
    • abit
      • Jul 2011
      • 418
      actually you can't mess it up, long end will go in early type gear bushing, and bend is for gearbox guibo, so, bend faces down.
      aaaand shifter, just put it in one way and another, in one way It should be waay off normal position.
      http://instagram.com/mundieriss
      my 88' m20b30 HERE!
      • Mastrcruse
        • Sep 2005
        • 5340
        Next question (thanks for the help on the shifter) - rear mount. I repainted the tunnel so I’m not sure which hole the rear mount goes into. If I remember correctly, it was the lower one but wanted to confirm. Top or bottom? Thanks!
