Diff Swap Help
  • 808ETA
    • Nov 2018
    • 436
    Diff Swap Help
    My diff swap is turning into a can of worms. I bought a 3.45 open diff from someone however I'm not 100% which car it came from. I believe it's either a z3 or 318ti because the differential flange cover has the thinner o-rings and the output shafts are the shorter “dumbo ear” style. When I bought the o-rings and output shafts the part numbers showed a range of years and models. My car is an 84 ETA and my speedometer pulse sender plug has a different connection. Since the pulse sender is shorter in the 3.45 diff I'm not sure if swapping the cover will work. Is it possible to solder in a late model pig tail? Any help would be greatly appreciated. BTW the diff looks to be the same size and dimensions to bolt up.
    sigpic84 325e
  • 808ETA
    • Nov 2018
    • 436
    So the diff is from a 318ti. Still trying to figure out if I need to swap the diff cover or just change the pigtails
    sigpic84 325e
    • bmwman91
      • Oct 2004
      • 3134
      See if you can get the old pulse sender to work in the new cover first. If you get a speedo signal, then it is fine. You can always put in the 318ti sender and splice the connector on after everything is reinstalled.
      Transaction Feedback: LINK
      • 808ETA
        • Nov 2018
        • 436
        Thank you for your help! The old pulse sender is actually longer and bottoms out. My pigtail just came in so I will probably just splice it.
        sigpic84 325e
        • 808ETA
          • Nov 2018
          • 436
          Update. Got it in and it makes a big difference over the 2.79 that came in. I used the 318ti diff cover and speed sensor. I just changed the sensor pigtail on the car.
          sigpic84 325e
