LS1 swap -- engine starts then immediately dies.
  • milosav2
    • Aug 2020
    • 9
    Hi all. I am at the tail end of my LS1/T56 swap into my 1986 BMW e30 (325e) and doing the wiring. Now that I have everything hooked up, I am running into an issue. When I go to start the car, it starts and then immediately shuts off. When I say immediately, I mean less than a second.
    I have access to hp tuners and have the oem tune on the pcm. After much googling and trying different things per some forums, here is what I have tried to no avail:
    1.) VATs is off. (I have an hptuners to verify).
    2.) Tested for spark – good.
    3.) Tested fuel injectors for power/pwm signal with a DMM and noid light – good.
    4.) I have ground wire to the back of the driver side head and another from block to chassis.
    5.) I have the ignition hot activation wire (needs 12V when key is in start and run position) going to pin 7 of C101 connector: https://ibb.co/LNV6mhV . I see 12V when in ‘run’, but it does drop off to around 10V when cranking.
    6.) Fuel pump does pressurize the rail to around 55-60psi. I can also hear it.
    7.) The following I don’t have hooked up: MAF, IAT, O2 sensors.
    If anyone has any other ideas I could look at please let me know. I have an hp tuner and if anyone has any ideas what to look for in the vcm scanner: https://ibb.co/1nPpYx9 fire away.
  • tyeler18
    • Jul 2019
    • 141
    VATS. Do a write entire when you disable VATS not a write calibration, it'll say it's disabled in the OS, but without a write entire it will not actually disable VATS. I keep running into this for some reason even from reputable hptuners mail order tunes.
    • Supadave
      • 1006
      What happens when you give some gas? Have you set your IAC?
      https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
      • iansane
        • 1343
        Hook a MAF and IAT up.
        84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
