???? brake booster question?????
  • e30euro
    • Jan 2010
    • 2219
    can i use the stock e30 booster or do i need to swap it out?
  • dirty30
    • 3013
    you need a whole e34/ e32 booster setup or a custom boosterless master cylinder...
    SEARCH!
    • slammin.e28
      שמע ישראל
      • 12054
      Have you read any of the posts in this section?
      • e30euro
        • Jan 2010
        • 2219
        i dont have time to read i work 100 hours a week so its hard to sit on here and read sometimes.
        • dirty30
          • 3013
          Here's a link that may help you out.
          Read it from start to finish and you should have a good idea of how much work goes into the V8 swap.
          • blck325is
            • Apr 2006
            • 1749
            This link is quite good and very detailed. Pretty accurate representation of the swap and the work necessary to do it.
            Originally posted by csermonet47
            Vlad, you are handling this quite unprofessionally.
            Also, you are a cock with tacky taste.
            That is all.
            • bimmer630
              • 1228
              Has anybody tried Hydroboost with a V8, or is that too tight?
              • bmwmech1
                • Jun 2010
                • 1075
                There is a guy in Europe that is putting an S62 in his E30 and is using a hydro setup, but the head/VC are slightly different on the S62 than the M6x V8, so for him it works. But he also moved the entire setup over about ~3 inches... I think he has a post in this section. I'll look for it and link it...
                Garey
                EDIT: Here it is... http://www.r3vlimited.com/board/showthread.php?t=208279
                • BruceBe
                  • 108
                  I picked up an H31 hydro-boost setup from a guy on CL, just to check it out. I don't think it really makes the brake problem with these swaps much easier. Once you get done with the firewall and pedal-box mods/fab, you still have clearance issues with the reservoir, and the brake lines going to the master - and the whole shittery is getting baked by the driver-side exhaust manifold.
                  Not a slam dunk, by any means.
                  -Bruce
                  • bmwmech1
                    • Jun 2010
                    • 1075
                    -Bruce
                    I know... I know you did a pretty slick mod in yours, Bruce and that's also why I went with the Wilwood pedal assy in mine. It is a mess of an area to have all that hardware in and getting baked to boot!
                    Garey
                    • einarsss
                      • Apr 2007
                      • 101
                      Thread steal!
                      Anyone got the e34/e32 booster+bracket for sale?
                      And one related question.. Is it possible to use the stock 325 MC with it?
                      E30 3xxi - BRILLANT ROT
                      • Jean
                        • 18228
                        Shipping to Iceland would be bank! I have an e34 booster/mc with all the hardware and I think I have a spare e30 MC so I'll try and check that for you to answer your question on fitment.
