M6X Cams
  • Jean
    • 18228
    M6X Cams
    Alright, lets talk about cams and what's available out there for these beasts :)
    I am going to get some factory / OEM cam info added to this post later. Hopefully we can expland with aftermarket choices/selections as well.
    M60B30
    M60B40
    M62B44
    M62TU 4.4
    M62TU 4.6
    M62TU 4.8
  • Jonsku
    • Oct 2004
    • 566
    VAC Motorsport?
    Schrick?
    M60 cams are a bit wilder than M62 cams. Don't know of S62 cams, though. Might be much different due to Vanos.. ?
    I'm just throwing out ideas, lets see if we can find any real answers :)
    - E34 M5 (x 2) -
    - E30 V8 Cabrio "Kylpyamme" -
    - Alpina D10 Touring #33/94 -
    - E46 318i Touring -
    - Toyota Hiace 4wd -
    • Wanganstyle
      • 2828
      m60 cams are a lot more lift, seems like a much higher rpm range powerband. (dual valvesprings vs single), more aggressive cams.
      perhaps break into 3 sections:
      obd1
      obd2 (non vanos)
      obd2 (vanos)
      • fanboi
        • Sep 2012
        • 136
        Wanting to bring this back. Like a good NOOB i searched all 14 pages of the V8 section. Looked at damn near every post and learned a lot but I was hoping we could expand on this subject a little more now that this swap is being done more.
        Also want to talk about regrinds, upgrading valve train, and all that.
        Discuss....
        Odd man out
        Vanos=Very Aggressive NOS???
        • JGood
          • Jan 2004
          • 7959
          Catcams has charts with factory specs and specs of all of their cam options.
          For the price you spend on a set of cams with supporting valvetrain components, you're 50% of the way to an s62... probably without much gain.
          e30 restoration and V8 swap
          24 Hours of Lemons e30 build
          • fanboi
            • Sep 2012
            • 136
            I dont want to go S62. I want to be different and actually do something with the m60b40. Yes i know its probably stupid and it makes more sense to go s62 or m60 with the 4.4 bottom end. i operate differently. I know it will be more expensive and I know it may not yield a lot more horsepower but its what i want to do. to me the v8 swap is like the m30 swap in the fact that nobody really opens them up and does anyhting with them. Just drops it in. that puzzles me. . anyways...
            Webcams also does regrinds on these and so do a few other companies. Stock if i remember correct is 249/241. cat cams will do a 258/247 without upgrading the rest of the valvetrain. unfortunately trying to get a hold of them is impossible since their phone number is inactive. What other companies out there will work on or have more options for the m60 motor?
            Odd man out
            • The Dark Side of Will
              • Jun 2010
              • 2796
              Cams work best in conjunction with porting and compression increases.
              M60B44 with cams and decent porting should be at LEAST a 360 HP engine.
