Slow v8 project from Iceland
  • einarsss
    • Apr 2007
    • 101
    5 speed transmission from ebay.com - check :)
    I guess I'll be burning tires through 1st and 2nd with my 3.25 lsd
    E30 3xxi - BRILLANT ROT
    • einarsss
      • Apr 2007
      • 101
      Gearbox arrived today.
      Pretty clean and slides into all gears, I'll be replacing all the oil seals to be on the safe side. Hopefully it will run this summer
      My cat drowning in plastic foam the came with the box
      • robiniscool
        • Jul 2010
        • 299
        1 step closer!
        • jaywood
          • Jul 2010
          • 4528
          Looking good! In for the progress ;)
          • einarsss
            • Apr 2007
            • 101
            Ok, I'm a little confused.
            Planning on LW flywheel for a e39 540i - it should fit right?
            Clutch.. Could I use a 240mm clutch intended for dual mass flywheel for 540?
            for those who havent read the first post I have m60b30 and 5 speed gearbox :)
            • Jonsku
              • Oct 2004
              • 566
              Yes, all the flywheels etc are basically the same.
              Clutch disc has different diameter center spline / clutch shaft joint for 6-speeder.
              - E34 M5 (x 2) -
              - E30 V8 Cabrio "Kylpyamme" -
              - Alpina D10 Touring #33/94 -
              - E46 318i Touring -
              - Toyota Hiace 4wd -
              • einarsss
                • Apr 2007
                • 101
                I've got 10 splines on the shaft, does 6 speed have more or larger diameter?
                Just wondering if a 540/m5 clutch would fit on this gearbox :)
                • einarsss
                  • Apr 2007
                  • 101
                  found a post from Garey (bmwmtech1) on bimmerforums that has the answer i was looking for
                  I'll jump in here with some definitive information... a bunch of us are using the 530i 5 speed in our E30 V8 swaps, since you don't really need the extra gear in the E30 and the size of the 5 speed is much friendlier in the E30 tunnel than the 6 speed. A racer on the West coast and I had been comparing notes on flywheel and clutch compatibility for a while between the x60/x62 V8s and the 5 speed box. Since the transmission is shared with the E36 M3, just a different bellhousing, we figured the tranny would be robust enough and he set out to find a workable, readily available clutch/flywheel package to use. I want to be sure that he gets credit for the R&D here since he spent a fair amount of time and money to find the correct applications and then was willing to [COLOR=blue !important][COLOR=blue ! important]share[/color][/color] it with everyone. Super nice guy Bruce is. What he found is this...
                  E39 OEM 540i Dual Mass flywheel or lightweight equivalent
                  E36 328i or E39 528i or Z3 2.8i clutch kit P/N 21 21 1 223 602
                  E34 530i clutch slave
                  Now, the OEM clutch kit part number is given, but I highly recommend finding an aftermarket kit of at least a Stage 1 variety. There is a significant enough difference in torque between the 6 and the V8 that premature wear/failure may happen and Stage 1 kits are plentiful and not too expensive.
                  The flywheel must be an E39 540i Dual Mass or lightweight aluminum like JB Racing's E39 540i flywheel because of the friction diameter and mounting pattern for the Pressure Plate.
                  This combination has been both Dyno tested and Track tested, so it works, it's readily available and it's not fiction.
                  I immediately thought of the E34 guys with the 540 automatics that want to swap to manual, but wanted a less expensive/elusive transmission to swap in. This would work perfectly for that application.
                  Bruce is currently tracking this combo in the Pacific Northwest... JB Racing's E39 540i aluminum flywheel and Clutch Master's E36 328i Stage 1 clutch kit with an M60 and 530i 5 speed trans in his E30. Same setup that is going in my M60/5 speed E30 M3 clone...
                  Just thought I'd share the info here, since Bruce was gracious enough to share it with me and on another forum, for all to benefit from...
                  Garey
                  Hope this is still valid :)
                  • robiniscool
                    • Jul 2010
                    • 299
                    i hope so too, post a picture when you have it, im scared to fork up money
                    • einarsss
                      • Apr 2007
                      • 101
                      haha, you do it first ;) I have to cough up more moneyfor international shipping+ import tax and vat that stuff to Iceland.
                      • einarsss
                        • Apr 2007
                        • 101
                        Does anyone have info on e39 535i clutch setup on the 5 speed? Wich flywheel could it be used with ... 530/535/540/m5
                        e39 540/m5 flywheel is basicly the same if using obd1
                        • einarsss
                          • Apr 2007
                          • 101
                          e34 v8 6speeds use a 265mm clutch with a bigger spline for the clutch disc to slip onto. the e39 6 speeds use the small spline so the r39 clutch will not work on an e34 6-speed box. The flywheel will work if the disc mating surface is the same dia.
                          Can someone confirm that e39 540/m5 clutch has the same spline/shaft size as the 5 speed?
                          If that is true then I shouldn't have a problem finding a flywheel and clutchkit :)
                          • robiniscool
                            • Jul 2010
                            • 299
                            im almost at that point so kinda scared, already accumulated almost all the parts for swap i just need to choose either arp headstuds or oem headbolts, then i can put everything together and finish the swap in a month haha but until i order my special tool for camshaft alignment and the stupid flywheel bolt socket ill see how long you last until you buy it first
                            • Garageaholic
                              Freestyle Fabricator
                              • Dec 2005
                              • 5204
                              They are different spline sizes. Call rob at UUC and he'll explain it all to you. To purport my statement, I did call him and he confirmed that my application(e34 540i/6) for lightweight combo would work for his kit, which is for the e39 540i/m5 6 speed, 240mm clutch. This will not work on 5 spd because of the input transmission splines.
                              Recent Rebranding!!
                              E30 SM62/S62
                              E30 M60 V8
                              E30 M30 Big 6!
                              Instagram.com/garageaholic
                              Youtube.com/garageaholic
                              • Jean
                                • 18228
                                there is no E39 535i here in the states :)
