I'm trying to figure out what goes where. This is what I gather, please correct me if I'm wrong:
-Water pump has 1 input and 1 output, both connect to radiator.
-Radiator also has extra nipple, which connects to reservoir.
-Reservoir connects to the rear coolant manifold/pipe.
-Rear manifold pipe comes with 4 nipples. 1 for the reservoir, another for the heater core? The other two can be eliminated?
-Lastly, the other heater core connection. Where does this connect to the cooling system? Surely it doesn't connect to the rear coolant manifold/pipe, or there would be no flow (without the aux water pump found in e32/e34).
