Sorry... I guess I'd said that on E30 tech but maybe not here.
Yes, moving the crossmember and rack together or moving the entire steering arm with the outer ball joint and tie rod end together will only change the point on the bump steer curve where the suspension operates.
Moving the rack relative to the crossmember or moving the tie rod ends relative to the ball joints will change the shape of the curve. "Change the shape" means "make it worse" because BMW did the best they could when they designed the car.
The only way to make a strut suspension free of bump steer is to put the tie rod and control arm in the same plane. In order to have realistic caster, doing this would require using wheels significantly larger than 14".
