M60 timing tool
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    M60 timing tool
    Does anyone have one to rent to a fellow e30 m60 swapper?
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
  • iamsam
    • Jun 2008
    • 176
    I have heard that holding the cams is doable w/o the tools if you are decent at jerry rigging.
    • Jonsku
      • Oct 2004
      • 566
      Yap but you don't have to mess it up by much and you'll instantly be losing lots of horses...
      I've a set but it's a bit long way to ship them :) Bought them from California for 100-150$ so shouldn't be too bad a investment..
      - E34 M5 (x 2) -
      - E30 V8 Cabrio "Kylpyamme" -
      - Alpina D10 Touring #33/94 -
      - E46 318i Touring -
      - Toyota Hiace 4wd -
      • Jean
        • 18228
        Frank, when I get my set back you can rent them for cost of shipping both ways. They are currently with someone else
        • Garageaholic
          • Dec 2005
          • 5204
          Interesting. Jean, please keep me updated.
          Planning on doing head gaskets in mid march.
          Recent Rebranding!!
          E30 SM62/S62
          E30 M60 V8
          E30 M30 Big 6!
          • iamsam
            • Jun 2008
            • 176
            I will need to do HGs on my B40 also soon... I was hoping to make my own tools (I have access to a manual lathe and mill in addition to the usual stuff like torches/grinders etc)
            • Jonsku
              • Oct 2004
              • 566
              One more comment.. there are M60's with two different timings "older" and "newer". The newer timing was changed to the engines by BMW after Alpina had timed their engine that way (makes idle smoother etc..)
              What I'm trying to say, that when going around with the timings, use the newer timing values (where other side is slightly tilted, not perpendicular to heads).
              I hope someone understood :)
              - E34 M5 (x 2) -
              • iamsam
                • Jun 2008
                • 176
                sano vaan suomeksi sitten.
                • Garageaholic
                  • Dec 2005
                  • 5204
                  Bump.....anybody have a tool to let me borrow? We'll talk turkey via PM .
                  Thanks a lot in advance
                  Recent Rebranding!!
                  E30 SM62/S62
                  E30 M60 V8
                  E30 M30 Big 6!
                  • dirty30
                    • 3084
                    I noticed this when I timed mine, they had a very slight slant to them in relation to the heads unlike a 6cyl where they are perpendicular.
                    • Garageaholic
                      • Dec 2005
                      • 5204
                      So I'm going to end up timing my m60 as I cracked one of the head gaskets when removing the upper timing case cover.
                      Jonsku, can you elaborate on where I can find the new timing values? Is there a writeuP as to how to time the m60?
                      Recent Rebranding!!
                      E30 SM62/S62
                      E30 M60 V8
                      E30 M30 Big 6!
                      • JGood
                        • Jan 2004
                        • 7959
                        The m/s5x's? They definitely aren't supposed to be perpendicular. Not under factory specs anyway.
                        e30 restoration and V8 swap
                        24 Hours of Lemons e30 build
                        • Jonsku
                          • Oct 2004
                          • 566
                          There are differences within the M60 range as well. First of them had "perpendicular" timing, whereas on later models the engine was timed so that other head bank / cams were slightly tilted.
                          So, when buying / borrowing the timing tools just make sure that the other side has tilted angle and you're ok.
                          - E34 M5 (x 2) -
                          • Jean
                            • 18228
                            My set is still at the bmw shop, I'll stop by this week to see if they are done :)
