325e/324td drive shaft for 5 speed swap
  • noid
    • 1536
    The 325e had 3 different drive shaft part numbers
    until 86 the part number was 26 11 1 225 635
    from 6/86-09/87 the part number was 26 11 1 226 210
    From 09/87+ the part number was 26 10 1 226 425
    Which one is it exactly that is supposed to work without modification with a 5 speed m60 swap?
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
  • JGood
    • Jan 2004
    • 7959
    You don't want part number 26111225635 (pre 6/86), that is the small guibo.
    My best guess for the 9/87 cutoff is that it's related to the center support bearing design change across all e30 models which happened in the same month, not the shaft itself. The reason realoem has 2 different part numbers is because when it's ordered from BMW, the shaft comes assembled with a CSB.
    So, if you are going after a used driveshaft, you should be fine with either 26 11 1 226 210 or 26 10 1 226 425, then get the correct CSB for your application.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
