Frank's E30 M60 V8 Swap Build Thread
Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Instagram.com/garageaholic
Youtube.com/garageaholic -
Hi Frank
I have an M62B44 swap myself, and am working on installind an OEM Airbox in the compartment (I had a CAI before, but want to get it stock looking as much as possible)
Which box did you use? Do you have any close up pics or info on what you modifed, I'm having a bit of a hard time to fit.
Thanks344is! Obd1 conversion
sigpicComment
cut the whole bottom plastics off little by little without reaching the filter itself until it fits lol thats what i didHi Frank
Thanks
It's easy job really, take the intake silencer away, cut bottom away and plastic-weld it back together while turning the "bottom pipe" around. Had a pic on it somewhere, though not online anymore.
It's a piece of cake, really. :)
Btw, E32 / E34 have the most suitable airboxes. Other models have much higher boxes (e.g. E31).- E34 M5 (x 2) -
- E30 V8 Cabrio "Kylpyamme" -
- Alpina D10 Touring #33/94 -
- E46 318i Touring -
- Toyota Hiace 4wd -Comment
Thanks guys
I have an e32 box, I was able to fit it without cutting it actually, but it's a tight fit.
I need to work on aligning the air vent from the box to the hole made for the air conditioning right behind the lights so that I get good fresh air ;)344is! Obd1 conversion
sigpicComment
Do you have any cooling issues with the E34 V8 radiator? What is it like on a hot summer day? I'm gathering parts for a swap here in Bangkok where it's 25~38 all year round.
As I've read on here, the Z3M radiator can be put to good use but they are hard to get here in Thailand. Any one had any luck with those aluminium radiators on ebay?
Cheers,
AndrewsigpicComment
Great thread lots of useful info, just wondering if anyone can see these pictures specifically about the driveshaft discussion????Update:
I've decided to use complete E30 driveshaft and have them weld the (smaller diameter of the M60 Front half) onto the front half of the E30 as well as shorten it to the same dimensions as mentioned a few posts ago.
One thing to note, The M60 and E30 driveshafts are NOT plug and play. In fact, they are polar opposites in terms of spline-male/female joints, spline size, and center bearing installation orientation.
With that being said, this new installation methodology is more factory-like, maintaining the E30 driveshaft. It requires just the front half to be shortened, and I get to keep the "sliding characteristics" of the spline. Perfect.
FYI: the E30 Front half diameter is 60.00mm. The "small sections" of the M60 front half diameter is 60.00mm. Perfect cut and weld compatibility.
Thanks so much for all of your help. you likely saved me some money and alot of potential compatibility heartache.
See pictures below of both driveshafts side-by-side for reference. E30 on top, M60 on bottom.
Spline size differences. M60 is much bigger.
If yes what must I do to view them.
ThanksComment
