A different approach to the v8 swap brake booster...
  • glucklich21
    • 1912
    #31
    You loose a master cylinder you are screwed. A line, not so much, but the master yes. I may have not put that in the most accurate statement.
    The solid stainless lines should negate the risk of loosing control to the slave cylinder and second to that is just the failure of the cylinder itself. The lines are rated well above the working pressure of the other brake components and if inspected every so often I see no problem. It's all just a calculated risk.
    • Holland
      • Nov 2008
      • 7212
      #32
      Oh how I love threads such as these.
      Originally posted by DEV0 E30
      • Van Westervelt
        • 9365
        #33
        Why not just run a boosterless master cyl...?
        • glucklich21
          • 1912
          #34
          Because then your brakes are shit for the street. I for one don't want to force a solid pedal down in an emergency.
          • Exodus_2pt0
            • 5943
            #35
            Originally posted by JGood
            From my understanding...
            It's completely different. The master cylinder has two separate reservoirs, feeding two separate circuits, and the compression of the brake pedal, and therefore the individual pistons, is mechanically activating each circuit individually regardless of the other circuits condition. If you blow a front brake line, you still have rear brakes, and vice versa.
            With a remote system, if you blow that single line, you lose it all, there is no backup to help you slow down.
            Correct.
            What you fail to realize is that a master cylinder has 2 separate chambers in it, making it very unlikely for the entire braking system to fail.
            You said if you lose a master cylinder you are screwed... so your response is to add in ANOTHER master AND a slave cylinder BEFORE the factory master that has a safety built in? You just tripled your chances for a catastrophic failure in one of the most important systems in a vehicle.
            This is a cool idea, but a bad one once you investigate it thoroughly. Then again, you cannot teach common sense.
            No E30 Club
            • dirtysix
              • 806
              #36
              Ford used to use a system similar to whats being talked about.
              Can see the booster in top right of this shitfull pic I found.
              And bottom left of this slightly better pic
              • BruceBe
                • 108
                #37
                Many of the OEM's used remote hydraulic braking systems 30-40 years ago. They also had lap belts, drum brakes, rigid bumpers, etc. That doesn't make it OK by modern standards.
                Go look at a cut-away view of a tandem master cylinder, and note the built-in mechanical failsafe if you lose a hydraulic circuit (regardless of whether it's the line, the caliper, or seal within the master cylinder itself that fails).
                -Bruce
                • dirtysix
                  • 806
                  #38
                  Yeah yeah yeah but naa. Be sweet as cuz.
                  • Jonsku
                    • Oct 2004
                    • 566
                    #39
                    Originally posted by kristov
                    How is the pedal feel compared to stock E30 pedal feel?
                    It's more or less similar. The linkage is basically the same as in V8 E32 / E34, so it has the "factory feel" in it. :)
                    - E34 M5 (x 2) -
                    - E30 V8 Cabrio "Kylpyamme" -
                    - Alpina D10 Touring #33/94 -
                    - E46 318i Touring -
                    - Toyota Hiace 4wd -
                    • ajune
                      • Jun 2013
                      • 36
                      #40
                      just gonna drop my 2 cents in this most likely dead thread. what about using a dual master slave setup with hardline running all the way from the masters to the slaves that are driving the booster?
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        #41
                        Bump...check this shit out.
                        • jalopi
                          • 2370
                          #42
                          Undoubtedly cool, but it seems to be British made, so I'm not entirely sure I trust it
                          • slammin.e28
                            שמע ישראל
                            • 12054
                            #43
                            Ya, but most of the brake boosters in BMWs are Lucas....
                            No electrics, so it'll work.
                            • jalopi
                              • 2370
                              #44
                              solid point, just gotta watch out for rust then :D
                              • e30_302
                                • Sep 2013
                                • 453
                                #45
                                A Porsche 914 master cylinder (19mm), with the Massive booster delete setup feels great.
