A different approach to the v8 swap brake booster...
  • LJ851
    • 7919
    #46
    Originally posted by e30_302
    A Porsche 918 master cylinder (19mm), with the Massive booster delete setup feels great.
    That's gotta be expensive !
    Lorin
    The M30 is God's engine.
    • LJ851
      • 7919
      #47
      That small dual circuit unit should work great in our cars. Bonus points cause you could mount it anywhere, like under the back seat for better weight balance.
      Somebody should do this.
      Lorin
      • e30_302
        • Sep 2013
        • 453
        #48
        Sorry, super cars on the brain I guess. That should read a 914 master cylinder. $80 on eBay.
        • slammin.e28
          שמע ישראל
          • 12054
          #49
          This.
          ....but would have to be plumbed in before the ABS block if one wasn't building a BCUZ RCECRR.
          • jksmith
            • Feb 2015
            • 17
            #50
            you have any pics of your set up ? are you running a prop valve if so which one? Running a Reservoir?
            I am doing a AUTO v8 set up and was wanting to use the Massive Booster Delete along with a Wilwood MC and run it to a prop valve then to each brake,
            • e30_302
              • Sep 2013
              • 453
              #51
              Summit racing prop valve, and yes, I have a fluid reservoir. Sorry, no good pictures at the moment.
