My E34 540i 6spd harness also has this secondary air pump stuff that I think I can remove, kind of surprising seeing as how the ETM shows this only on a 530i/t. What did you do with the small brown/blue wire that runs to the DME? Also, the connector that comes out of the front of the passenger side harness pack can then be removed yeah?
My harness also has the small black/green wire going to a ring connector near the ebox, I'm going to follow your lead and stick it in slot 15 on the X20 engine side, then connect that to pin 15 on the C101. Thanks for the help!
