Bleeding m60 coolant
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    I know the system is self bleeding, but I can't get flow to the radiator or heater core.
    System mimics the stock 540i coolant system 100%, with the expansion tank in its appropriate location.
    So the tank is filled to the brim, engine is running. No heat with heat turned on. No coolant to radiator. Feels like the radiator hoses are empty when squeezing.
    Turned engine off after 3 min at risk of overheating.
    Tonight im thinking of checking my tstat to see if the "expansion valve" in the tstat is facing 12 o clock position...I don't remember how I installed it , but I do remember not being cognizant of the direction of that valve.
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
  • Garageaholic
    • Dec 2005
    • 5204
    Fixed. The tstat was correct. I just had to be patient. When I had that big "gulp" sound from the expansion tank. I knew that the tstat opened and then the heat started working. Right at halfway. Perfect.
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    • dirty30
      • 3008
      Glad you got it figured out... its always scary filling a completely dry cooling system. Its even scarier when its all aluminum!
      • JGood
        • Jan 2004
        • 7959
        I can't get my coolant system bled. It overheats very quickly with the cap installed.
        I removed the cap, started the car, and in about 3 minutes it will boil out over the resevoir for a few seconds, at which point I shut the car off, and then the level drops significantly. As it does, I add more water, until the level stabilizes (not allowing the system to suck any air from the reservoir). Start the car, and repeat. I've done it probably 100 times.
        My heater core is getting (very) hot coolant, so the system seems to be flowing.
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • 325ix
          • Aug 2009
          • 7783
          Well, I don't have an M60 but, I'm working on bleeding an M62 right now. It's kind of a pain.
          • Jonsku
            • Oct 2004
            • 566
            I don't understand how it can be so difficult? I've never had ANY problems when bleeding BMW V8's, they are much, much easier than M5x engines that can sometimes cause bit of a trouble..
            Just fill coolant level up, let engine warm until thermostat opens and then add coolant until amount is right. Test drive and check level next morning, end of story :)
            - E34 M5 (x 2) -
            - E30 V8 Cabrio "Kylpyamme" -
            - Alpina D10 Touring #33/94 -
            - E46 318i Touring -
            - Toyota Hiace 4wd -
