Cooling system observations
  • BruceBe
    • 108
    Hello everyone,
    It's been a little while, but development of our M60-equipped race car has resumed, and we've finally worked-out the oiling-system gremlins, managing to keep the car on track for a double race weekend over the memorial day holiday.
    We have a Mishimoto E36 M3 radiator, and a smaller 12" electric pusher fan of unknown origin, that has been on the car for at least 10 years. The vehicle also has a stock thermostat. While it was clear/sunny, ambient temps probably didn't exceed about 70 degrees all weekend. The altitude at the track is about 2250 ft.
    Equilibrium ECT during the races was about 210-212 degrees, and EOT stabilized at about 245 degrees. Engine oil temp is being measured coming out of the block, before the filter/cooler.
    Coming off track, heat-soak at the scales, and maneuvering to our paddock location was problematic for the cooling system. I'm not sure if it was a runaway condition (I wouldn't leave the engine on that long), but ECT would incrementally rise at idle.
    I would like to see ECT at 180-190 degrees on-track, and ideally, something very similar when putting around the paddock and waiting at the scales. One issue I see is the *evacuation* of dirty air after the radiator. The V8 presents quite a bit more frontal area to the radiator, and the engine maintains quite a bit of girth all the way to the firewall. If I place my hand in front of the radiator next to the fan, I can feel airflow back out through the front of the radiator.
    Our plan is to upsize ye ole pusher fan (Garey, which one do you have?), and create side/bottom shrouding to prevent air spillage when the car is at speed. While that alone is probably enough to get temps under control, we're also going to upgrade to the Mishimoto Z3M radiator (PM me, if you want a screaming deal on a 1 year-old e36M3 Mishimoto rad). At some point, we'll likely add strategically located hood louvers, to aid in evacuation.
    Is there a source for a lower temp T-stat for these engines?
    -Bruce
  • bmwmech1
    • Jun 2010
    • 1075
    Hey Bruce, good to hear the the car's on the track again! To your points, I have a 16" fan, I'll have to find the name of the website I got it from and an adjustable controller with a probe style sending unit. The controller was cheap and I needed it quickly, so I just grabbed one from Summit. I plan on going to a screw-in style, just have a lot more fish to fry beforehand. There is a source for a cooler thermostat, it's the one from the 850CSI. It is an 85 degree thermostat and the stock V8 one is an 95 degree. Part number for the 850 T-stat is 11 53 1 729 720. I think the combination of the Z3M rad and fan upgrade will do the trick. Add the cooler T-stat and I think you'll be golden. Get some action shots of the car at speed if you can. I know everyone would love to see them!
    Garey
    • dirty30
      • 3014
      -Bruce
      BMW has one for hot climate Bruce
      85 cel thersmostat
      11531729720
      I am using a spal 16" pusher if that helps at all.
      • dirty30
        • 3014
        Garey
        BAH! beat me to it!
        • BruceBe
          • 108
          Ask and you shall receive - thanks guys!
          I'm working on a short video summary of the weekend, with in-car and a drive-by from the pit wall. I'll post a link as soon as it's done.
          -Bruce
          • robiniscool
            • Jul 2010
            • 299
            i currently have the 95C thermostat and it scares the ^#$* out of me in a e30 temperature gauge which is about at the 3/4 mark all the time definitely worth going for the 85C one, it will stress me out less
            • JGood
              • Jan 2004
              • 7959
              Mine sits right at the half way mark all the time with the stock thermostat. I do have a huge Mishi Z3M rad with a 16" fan that almost constantly runs, though.
              e30 restoration and V8 swap
              24 Hours of Lemons e30 build
              • robiniscool
                • Jul 2010
                • 299
                i definitely now need a bigger radiator and fan
