m60b40 missing, low idle, back firing
  • JGood
    • Jan 2004
    • 7959
    #61
    Tried another set of coil packs, no change. Also verified that I'm getting 12v to the coil pack harness connectors.
    That was the last part that I could try. I've replaced everything else at least once:
    ICV
    TPS
    CPS
    Temp sensor
    MAF
    O2 sensors
    DME
    coils
    plugs
    I've tested the harness, end to end. I've vacuum smoke-tested and compression tested the engine.
    There is nothing else...
    As of now, it runs without stalling with the o2's unplugged. But it backfires loud as hell, throttle on/off is jerky, and it runs VERY rich.
    I'm going to order another TPS and ICV (although I've already tried 2 of each, and both ohm out as being good)
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • Jonsku
      • Oct 2004
      • 566
      #62
      Read fault-codes.
      Cheat DME so that it thinks AC is on all the time.
      Not the wisest thing to change parts blindfolded..
      - E34 M5 (x 2) -
      - E30 V8 Cabrio "Kylpyamme" -
      - Alpina D10 Touring #33/94 -
      - E46 318i Touring -
      - Toyota Hiace 4wd -
      • JGood
        • Jan 2004
        • 7959
        #63
        Yes Jonsku, I blindly threw parts at it before troubleshooting anything, didn't I?
        I did read the codes, as I've mentioned. The only standing codes are the canbus code and the purge valve code. Also the lambda/o2 codes, while the o2 sensors are unplugged.
        The idle speed isn't the issue, bumping it won't fix the actual problem.
        • senorcarey
          • Apr 2012
          • 80
          #64
          Did you, perhaps inadvertently, knock the throttle plate/TPS out of adjustment? I had this problem on my M30B35 and it makes a significant difference in running.
          Just a thought...
          Good luck,
          Scott
          • Jonsku
            • Oct 2004
            • 566
            #65
            Ahh, shouldn't post to threads when having a great hangover :D Sorry for that.
            Anyway, what about the exhaust gases? Are they ok, or highly off (would think so..)? Do the plugs look ok? TPS - is it connected with the correct plug (two plugs with similar length wires, another one is for ASC's TPS).
            Have you tested that each and every coil gets good signal from ECU & +12V? Not just circuit continuity test, but proper "loaded circuit test" .. ?
            - E34 M5 (x 2) -
            • JGood
              • Jan 2004
              • 7959
              #66
              Just a thought...
              Good luck,
              Scott
              The newer TPS's are non adjustable. It's just a potentiometer, there is no on/off. It gets ~1k to ~4k ohms as the throttle is moved from open to closed, per Bentley specs.
              Originally posted by Jonsku
              Ahh, shouldn't post to threads when having a great hangover :grin: Sorry for that.
              I don't have a way to measure exhaust gases, I don't have a wideband o2. But I can tell it's very rich.
              The TPS is connected with the correct plug. It's the one with the spring loaded clip, from what I understand. The ACS plug has a PITA clip that requires a pick to remove. I plugged my multimeter into the DME connector, on the corresponding TPS pins, and then moved the throttle plate, and watched the ohms go from ~4k to ~1k at the DME. So it is hooked up correctly.
              Honestly, this thing acts EXACTLY like it has a TPS issue, so I see your point with that. I just can't seem to find any fault in the TPS system.
              I'm not sure what you mean by a loaded circuit test of the coil packs. I unplugged them and turned the key on, and each harness connecter gets 12v. Actually, 6 of them got 12.01 volts, and 2 got 12.11 volts. Which was intriguing, but not concerning, IMO. Is there anything else to test with the coil packs? I thought you couldn't test the actual spark side of the coil, other then seeing spark in the plug?
              • senorcarey
                • Apr 2012
                • 80
                #67
                Thanks, I didn't know that. Is there still a spec for throttle plate opening, like 0.002", or whatever it was for the earlier cars? Or is it completely shut?
                • Jean
                  • 18228
                  #68
                  Don't give up, need to figure out what is causing this
                  • barry
                    • 1642
                    #69
                    Steam your gas tank and use HO gas.
                    GL
                    • JGood
                      • Jan 2004
                      • 7959
                      #70
                      GL
                      I don't know what that means.
                      • Jonsku
                        • Oct 2004
                        • 566
                        #71
                        Yeah, then it's the right one and seems to work ok (though one could check the TPS resistance values somewhere, just to be sure).
                        You could test the signal wires from DME to coils (three wires going to coils, one is +12v, other is the signal from DME and third is shield-ground).
                        "loaded circuit test" means that you don't just "beep" the wires (check continuity), but actually load the wire with +12V (connect battery over the wire, be sure to load the wire by e.g. H4 bulb). Then by measuring voltage over the wire you can see if there are losses (=is the wire broken somewhere).
                        That is very handy method, as continuity test doesn't actually tell you anything on the real condition of the wire. It could well be "broken" somewhere - continuity test tells that it's ok but as soon as the wire gets loaded it loses 2/3 of the voltage somewhere, causing problems.
                        Anyway, that's just one idea. Do the spark plugs look ok?
                        - E34 M5 (x 2) -
                        • JGood
                          • Jan 2004
                          • 7959
                          #72
                          Thanks, I'll give it a shot. I have a pic of the spark plug on the first page of this thread, looked pretty normal to me.
                          One interesting thing, at the drag strip last night, after two of my runs the throttle hung at 2k RPM's. I slowed down at the end of the track, and the throttle just stayed pegged at 2k. I could put the car in gear and it would bring the RPM's down, but it would accelerate the car and as soon as I pushed the clutch in it would go back to 2k. I turned the car off, turned it back on, and the idle returned to normal.
                          This gives me even less faith in my questionable ICV. I'm going to grab another one.
                          • Jonsku
                            • Oct 2004
                            • 566
                            #73
                            But do all of them look similar?
                            That's not a ICV fault, but a speed-signal fault. You can try that somewhere on open road - as soon as you go over certain speed (if I remember correctly it was somewhere around 180km/h) and DME won't get good speed-signal, it will get mixed up and start messing around with the rpm's and will also start running very lean (temps go up).
                            From where have you taken speed-signal to the DME? I've taken it from the instrument cluster ("OBC connector") and seemed to hold fine up to 285km/h (rev-limiter cut in at dyno, 6800rpm / 6th gear :) ).
                            - E34 M5 (x 2) -
                            • JGood
                              • Jan 2004
                              • 7959
                              #74
                              I took it from the green connector on the back of the cluster. It only did it on 2 of the 9 runs, so I don't think it was the speed input. I've had it up to higher speeds on the street, no issues.
                              • RobertK
                                Kicked cancer's ASS.
                                • Jun 2005
                                • 5864
                                #75
                                I may be able to score you an ECU from an E34 540i 6spd for comparison if you still think the fact that its an auto ECU might be a factor.
