Can removal
  • senorcarey
    • Apr 2012
    • 80
    Can removal
    Quick question, can the cans be removed without the special tool and without rotating the engine? Just by slowly taking pressure of the cam caps?
    I know they are hollow and short versions of m5x cams which can be easily cracked.
    Thanks!
  • iamsam
    • Jun 2008
    • 173
    the cans?
    • senorcarey
      • Apr 2012
      • 80
      Ugh. Cans=cams.
      Auto-correct got me again.
      • Jean
        • 18228
        Yeah cams can be removed w/o special tools.
        • senorcarey
          • Apr 2012
          • 80
          Thanks, Jean. I am sans Bentley, but I believe that evenly loosening the caps from outer to middle is the way to go?
          • Jean
            • 18228
            Yeah, but keep in mind it will bind if the front chain is connected...
            • iamsam
              • Jun 2008
              • 173
              is the M60/M62 an interference engine? If not, you can just rotate the cam to the point where it is applying the least force on the valves and then unbolt it.
              • Jean
                • 18228
                it is
                • idanity
                  • Jun 2006
                  • 775
                  3 pedal club
                  200,k+ club
                  cabrio club
                  port-matched- polished- purring www.BMWpark.org
                  </div>
                  linux since 1999
                  • senorcarey
                    • Apr 2012
                    • 80
                    Done and done...
                    • iamsam
                      • Jun 2008
                      • 173
                      good to see you got those cans out!
                      • bmwmech1
                        • Jun 2010
                        • 1075
                        For sure! Now he's got some extra nut/bolt storage, lol!
                        Now, what to do about removing the cams...;)
                        Garey
                        • idanity
                          • Jun 2006
                          • 775
                          never shoulda edited the 1st post...it was full of cans and funny.
                          3 pedal club
                          200,k+ club
                          cabrio club
                          </div>
                          linux since 1999
                          • senorcarey
                            • Apr 2012
                            • 80
                            Fixed it for ya... ;)
