Engine stand mounting options
  • senorcarey
    • Apr 2012
    • 80
    Hi All,
    I am pulling the engine off of the hoist to gain more room in the garage. Other than crating and welding up a plate to mount it to the motor mount area, is there any issue with using the two threaded M10 as well as the two short M10 holes on the block?
    I need to take the pan off and I have a standard engine stand. I did search on the net, as well as Jeans thread and saw that this is how he mounted his, but I will have the heads still on mine.
    Thanks for any insight.
  • JGood
    • Jan 2004
    • 7959
    The only 4 I could get lined up on my stand were the 2 M8 bolts at the top, and 2 of the bottom M10 bolts. It was on the stand like that as I unassembled and reassembled it, for almost 6 months, constantly moving it around, etc... I left the heads on mine as well. I know it was questionable, but it worked!
    So if you can get 4 m10 bolts lined up, I'd say you'll be perfectly fine.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • Jean
      • 18228
      Just don't YANK on anything while it's on the stand if you are using the starter/tranny bolt/hole areas..... <crack>
      I priced the oem engine mounting "arm" that bmw has listed in their shop manual, and it was too expensive for what it is (over $300 iirc), it let's you mount the engine from one of the sides (passenger I think).
      • 5Toes
        • 9836
        I used 3 bolts from Lowes.. worked for me
        stand was outside for a month with motor on it
