So I started this thread to address a specific concern of mine regarding a specific incident, and also this thread can be a good source of technical info for anyone curious regarding cyl wall coating vs. sleeving etc, and why BMW chose to do that.
My specific scenario:
- pulled the heads off of an M62B44 NV
- one head bolt wouldn't come out of the head all the way due to interference w/ the cam
- that bolt dropped down as I lifted the head
- the weight of the head pressed the threads of the bolt into the cyl wall
- the threads ONLY damaged the cyl wall at the VERY top, ABOVE TCD where the rings stop
Will this be a problem, or can I clean up the area and proceed w/ the franken build?
The biggest problem I see is the small area w/ lack of coating. The only thing this area will see is the combustion chamber. Since the heads aren't coated w/ the same stuff, I assume this is ok?
Thanks guys
Thanks guys
