What's the best rearend (Diff) for M60 swap?
  • MonkeyMadness
    • 3251
    Getting ready to start collecting parts for a swap for my son and i have a question I have not seen answered yet. I've also done a quick search and didn't come up with a convincing answer.
    I looking to a M60 Auto swap, what would be the best rearend for the situation.
    thanks
    jer
  • iamsam
    • Jun 2008
    • 176
    An M60 auto swap? into an E30? why?
    Also, you spelled "tension" wrong in your sig.
    • Jonsku
      • Oct 2004
      • 566
      Some people like autoboxes, some like manual boxes :)
      Just completed one E30 V8 auto - swap. It's very nose-heavy, but if you like autobox - then why not?
      That one has 2.93 diff (same as originally in E32 / E34), keeps the revs nice and low but if you would want to have a touch more acceleration I'd go for 3.15 or similar. It's five-speeder anyways, so I wouldn't go too much higher.
      In my 6-speed manual I've 3.4 diff with 245/35-17 tires and the revs are a tad on the high side when on highway..
      - E34 M5 (x 2) -
      - E30 V8 Cabrio "Kylpyamme" -
      - Alpina D10 Touring #33/94 -
      - E46 318i Touring -
      - Toyota Hiace 4wd -
      • MonkeyMadness
        • 3251
        Cause that's what my son wants... is this an issue?
        Fixed..
        Good to know thank you very much.
        • JGood
          • Jan 2004
          • 7959
          There is no 'best'. This is sort of a subjective question, so it's a matter of personal preference. Some people like closely spaced gears, some people like longer gears. Some people like being up high in the RPM's on the highway, others prefer the lowest RPM possible. Do you want max MPG on the highway, or max acceleration?
          Best way to figure it out is put your numbers into a gear ratio calculator and see what RPM you'll be running in each gear at any given MPH. You'll also be able to see your top speed in each gear, what RPM's you'll be at when you shift at any given RPM, etc...
          http://www.f-body.org/gears/
          If you are using the 5hp30, here are the ratios:
          1st: 3.55
          2nd: 2.24
          3rd: 1.54
          4th: 1.00
          5th: 0.79
          Rev: 3.68
          e30 restoration and V8 swap
          24 Hours of Lemons e30 build
          • bmwmech1
            • Jun 2010
            • 1075
            Just remember that a V8 automatic in the E30 requires fabrication work to the trans tunnel, it's not just a bolt-in affair. The 5 speed automatic is a humongous transmission, even compared to the 6 speed manual, which is a big transmission. The manual transmissions are a much "friendlier" swap... in case you weren't aware.
            Garey
            • robiniscool
              • Jul 2010
              • 299
              i got random m60 parts from my swap, just hit me up, who knows maybe ill have something you need
              • JGood
                • Jan 2004
                • 7959
                Got an extra TPS, purge valve, or intake temp sensor?
                • robiniscool
                  • Jul 2010
                  • 299
                  yes but off a m62 obd ii manifold and thats drive by wire =(
                  • dirty30
                    • 3091
                    Garey
                    I'll second this. That 5 speed auto is a monster!!
                    • Jonsku
                      • Oct 2004
                      • 566
                      Garey
                      Oh yes, it is BIG! (here's a comparison pic between M20 + auto and M60 + ZF 5HP30: http://v8cabrio.kuvat.fi/kuvat/02_M2...+vs+M60_up.JPG ). The autobox itself weights around 120..130kg so it needs to have proper transmission mount :)
                      Actually the autobox will drop into the gearbox tunnel quite well, you need to massage the walls a bit with a sledgehammer - but surprisingly small amount anyhow..
                      Here you can find pictures on my latest E30 V8 swap for a friend (cabrio with autobox, AC, cruise, electric seats etc..); http://v8cabrio.kuvat.fi/#/kuvat/
                      - E34 M5 (x 2) -
                      • iamsam
                        • Jun 2008
                        • 176
                        I am personally offended! ;)
                        Tell your son to want a manual trans, it would be easier and more robust. That said, I would have sold you my auto trans in a heartbeat that I got from my donor car, but I scrapped it.
                        • MonkeyMadness
                          • 3251
                          Good.... :pimp:
                          What my boys want my boys get. They do what I need them to do and they earn it.
                          That being said Brogan (my oldest) just graduated Navy Boot camp with Honors. He wants a v8 Auto Swap. Plus He's also paying half..
                          He earned it...
                          Jenson my youngest 3 next month, All he ever want to do is ride in "Yellow"
                          my Lotus Elise. So if he's a good boy, that what he gets!
                          • The Dark Side of Will
                            • Jun 2010
                            • 2796
                            Good.... :pimp:
                            He earned it...
                            Congratulations to him!
                            Here's my take on the Autotragic swap:
                            I *think* that the 5HP24 (BMW nomenclature: A5S440Z) and 4HP22 have the same pattern mounting the transmission to the bellhousing.
                            Get the 5HP24 bellhousing and mate up a 4HP22 to it. The 4HP22 can be built to handle the V8. That way you don't have the extra work involved in fitting the larger transmission. Also, the 4HP22's taller first gear will work better with the high torque and limited traction that an E30 V8 will have.
                            However, the bellhousing interface commonality remains subject to verification...
                            • DDF_Dutchie
                              • Aug 2012
                              • 22
                              Nice topic.
                              I'm curious about the current v8 builds an diff/gear setup.
                              Like if a 2.xx diff with 6 speed still has crazy torque feelin.
