M62 swap DME power supply
  • kevinbednarek
    • May 2012
    • 35
    So, as I'm coming along in my swap, I've run into the dreaded (for me at least) wiring portion. My question is, how does one go about connecting power to the ECU? I'm sure it's really simple, but I can't figure out how to go about fusing it. Do I need to somehow wire in a set of relays to control the power? It sounds really dumb, but I'd appreciate the help.
  • JGood
    • Jan 2004
    • 7959
    You'll just be connecting the factory m62 harness DME power wire directly to the e30 fused battery wire on the firewall. Right above the large e30 battery cable junction on the passenger side firewall is a small power wire that also comes from the battery, which is fused (in the trunk). You're going to get your +12v for the DME there, just as the factory e30 DME did.
    e30 restoration and V8 swap
    24 Hours of Lemons e30 build
    • robiniscool
      • Jul 2010
      • 299
      hmm so close to me... you could drop by and see what i did lol
      • kevinbednarek
        • May 2012
        • 35
        Yeah? Where are you at?
        • robiniscool
          • Jul 2010
          • 299
          across the street from disneyland.. pm me
