MMP M62B44 Build Project "Jack-N-Coke"
  • Denny
    • Jan 2010
    • 822
    #376
    Denny
    ___________
    1990 BMW red 325IC M30B35 all stock Girlfriends ride
    1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
    Blogs:
    http://bmw325e30.blogspot.com/ (restoration)
    http://bmw325e30turbo.blogspot.com (Twincharge M20)
    http://bmw325e30m62b44.blogspot.ca/
    • MonkeyMadness
      • 3251
      #377
      Run test #2
      • econti
        • May 2014
        • 1112
        #378
        That looks sexual with the red rocker covers.
        What's the next step? Tidy it up then tune?
        • MonkeyMadness
          • 3251
          #379
          Yes. Clean everything up. Work some bugs out. Figure out my tach. I'm not getting a signal to my cluster so will be working on that next. Need a new belt. Coolent, ect.
          • Denny
            • Jan 2010
            • 822
            #380
            Originally posted by MonkeyMadness
            Run test #2
            Sounds really good cant wait to see this car in action.
            Denny
            ___________
            Blogs:
            • MonkeyMadness
              • 3251
              #381
              Ok so got the tach working.. Looks like my garagtastic tack sender thingy was in the way????
              So i pulled it off and the damn thing woke right up...
              So I try placing the garagtastci tach thingy in my adapter harness thingy. I'm pretty sure it was just my placement my inability to wire shit right....lol
              • LoneWolf
                • 402
                #382
                So you ended up not using it or rewiring it?
                • MonkeyMadness
                  • 3251
                  #383
                  Well I'm at a loss now.
                  I had it wired in behind the cluster, if you look back further in the build I documented the fitment in this build. well first thing i noticed was my tach not moving, so thinking "maybe I made a mistake" I would check the one think I messed with... So after checking both the harness adapter and the tach thingy and not finding anything wrong I pulled it off just to see if the tach would work at all.. and it did...
                  So I put the dash back together with out the tach thingy cause I know that all works. So my thought was I'll just wire the tack thingy into my harness adapter. But still nothing so I tried testing the thingy and I couldn't get anything to work....Crap....
                  So I sent a message to Garagistic explaining my problem and issue. Hopefully I'll hear back from them soon.
                  So, finally had time and the needed info to get back to project Jack-N-Coke
                  So today i installed the Garagetastic tach mod for the V8 swap.
                  Decided to mount this on the "blue c1" plug off the back of the cluster. Keeping in the cab, away from harm.
                  So if your interested in doing the same I'll post up the info below.
                  Blue C1 connecter
                  Soild brown = Negative/Ground
                  Grn/yellow = 12v/Positive
                  Pin #7 solid black splice this in dme to tach
                  Yellow to tach , white to dme.
                  Remember Garagetastic's mod requires a 4cyl tach plug. This mod will not work with the 6cyl plug
                  You'll need a Dakota Elc. Setup for the 6cyl.
                  [ATTACH]77077[/ATTACH]
                  [ATTACH]77078[/ATTACH]
                  [ATTACH]77079[/ATTACH]
                  [ATTACH]77080[/ATTACH]
                  After shrink rapping it and zip tie-ing it it the wire harness it is now protected and hidden
                  :beer:
                  • MonkeyMadness
                    • 3251
                    #384
                    Wow ok got my sunroof working. It was the gawd damn ground... loose
                    Everything is on the up and up.
                    Got my new coolant overflow tank but need hoses (coming soon)
                    Still need to figure out my tach issue. ugh
                    Once I get the tach finished I can finalize my harness adapter and finish this crap...
                    I can see the light at the end of the tunnel. I'm looking at killing at the next bimmerfest
                    fingers crossed..lol
                    • MonkeyMadness
                      • 3251
                      #385
                      So spent the day finishing the cooling system. Added a Huge OE fan and moved my other fan so now i have a low and high speed fans, as a pusher and a puller. Also mounted my new overflow tank with hoses. I'm really happy with it. It hides well in plane sight.
                      Also heard back from Garagistic, they want my tach signal thingy back and there sending me a new one. I thought that was pretty standup and cool on there part.
                      • MonkeyMadness
                        • 3251
                        #386
                        This is the placement I have for my overflow tank...:D
                        The I found this picture on the interweb and I would really love to hear this car as well as talk to the owner about how bad ass it is...
                        • Old city bimmer
                          • Jun 2014
                          • 1114
                          #387
                          Looks great. You got me beat to the finish.
                          I just wired my Dakota this weekend and got the TACH working. I still can get my temp gauge to work. I think I got a bad sensor or a bad SI board.
                          323i MTEC1
                          Z3 coupe
                          E60 M5
                          • Old city bimmer
                            • Jun 2014
                            • 1114
                            #388
                            323i MTEC1
                            Z3 coupe
                            E60 M5
                            • Chris916
                              • 183
                              #389
                              [ATTACH]87041[/ATTACH]
                              Lol thanks man, that's my car. Just got it going a few weeks ago. No good sound videos yet, but I'm hoping to take one this weekend. I love the sound, but it's really loud. Great for a toy to rip around in, but would not be fun as a dd.
                              You're build looks awesome btw, looking forward to seeing it go:up:
                              • MonkeyMadness
                                • 3251
                                #390
                                Sweet keep it going..
                                yea that's kinda what i figured. I was surprised you didn't add resonators in there some were.
                                I plan on a similar setup. But I'm planning to have resonators just behind the trans and separate mufflers per 2.5" out at the back..;D
