MMP M62B44 Build Project "Jack-N-Coke"
Denny
___________
1990 BMW red 325IC M30B35 all stock Girlfriends ride
1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
Blogs:
http://bmw325e30.blogspot.com/ (restoration)
http://bmw325e30turbo.blogspot.com (Twincharge M20)
http://bmw325e30m62b44.blogspot.ca/ -
Denny
___________
Blogs:
http://bmw325e30m62b44.blogspot.ca/Comment
;)https://www.forabodiesonly.com/mopar...re-irs.356333/
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.Comment
Only the late M62 and X5 are this configuration. On the early M62 the manifolds are two pieces on each side, meeting in a y-pipe on each side.Comment
I don't think an x-pipe or anything after the manifolds will make much of a performance difference. Most of us already have nearly straight-through designs, different mufflers will tune the sound. I have a magnaflow, as seems to be the most common, a flow master will probably give you a deeper sound. If you want to go in a different direction use the M60 or early M62 manifolds. It's way more work, that's why everyone uses the late M62 or X5 manifolds.Comment
Well I'm Keeping my header setup as is. I'm also thinking of keeping it a true dual to begin with. Running a set of SLP Cats #M310193500 for ( 2 ) reasons, -1. Being Hi-flow cats are perfect Resonators, -B. The one common element that all the bad ass euro v8 sounds that i have found run hi-flow cats, And -5. I'm hoping it will give it a tad bit more of a stock look if for some reason my car is inspected by the fuzz...
So after all that I will be running 2.5" all the way back to ( 2 ) Magnaflow 18146 4" x 26" and a ghay'ish stock looking tips to fool the grayhair's at the car shows...
and after all that not so cool sounding typed letter crap it will still support my build when i mount my SuperCharger under the hood of this beast.;D
Denny
___________
Blogs:
;D
Ok so I didn't get the SLP's like i wanted and now that option is at a higher price
But now i have another question before buying a different set.
If I'm going to run a cat as close to the headers as I can (that is my plan)
Should I get cats with with o2 sensor bungs in them or should I run the o2's before or after the cats?
I'm looking at a cat that i have the option of an o2 in the center..https://www.forabodiesonly.com/mopar...re-irs.356333/
Ok kool. The one I'm looking at now is a high flow with the o2 bung before the cat element but still in the body of the cat.https://www.forabodiesonly.com/mopar...re-irs.356333/
