MMP M62B44 Build Project "Jack-N-Coke"
  • MonkeyMadness
    • 3251
    #46
    But if i'm going obd1 and or MS whats it matter?
    I'm also picking up the flywheel with it...
    Yea Me :up:
    • Etexise30
      • Sep 2012
      • 208
      #47
      Yea Me :up:
      oh ok go for it .imma get my DME re programmed into manual for cheap locally and if it somehow becomes alive im sticking with VANOS
      • Jonsku
        • Oct 2004
        • 566
        #48
        Originally posted by Etexise30
        WAIT!!!!!!!!!!!!
        do not buy it yet u cannot use 4.0L trans on 4.4L but u can use 4.4L trans on 4.0L
        no its about a sensor that is used on the 4.4L not flywheel
        The transmissions are interchangeable, you just make the hole for the crank sensor (there's place for that on the side of the trans..)
        - E34 M5 (x 2) -
        - E30 V8 Cabrio "Kylpyamme" -
        - Alpina D10 Touring #33/94 -
        - E46 318i Touring -
        - Toyota Hiace 4wd -
        • Etexise30
          • Sep 2012
          • 208
          #49
          ohhh ok .i know there interchangable but i didnt know u could make the hole (bimmerforums-e39 section has a section of this issue)
          • TapOut
            • May 2011
            • 112
            #50
            how much are you asking for the mounts? can you pm me please
            • MonkeyMadness
              • 3251
              #51
              See here!
              • MonkeyMadness
                • 3251
                #52
                Quick Question...
                What OBD2 DME# should i run with the manual?
                DME7 501 290 Is this a OBD2 dme for a manual setup?
                Or is someone blowing smoke.....?
                • Etexise30
                  • Sep 2012
                  • 208
                  #53
                  Quick Question...
                  it really depends but u need DME7
                  • MonkeyMadness
                    • 3251
                    #54
                    Gratuitous Motor Pictures..
                    oh umm
                    • MonkeyMadness
                      • 3251
                      #55
                      oh ya..
                      Can i mount a 6spd flywheel and clutch with a 5spd trans????
                      • e30m3s54turbo
                        • Jun 2010
                        • 3228
                        #56
                        I am liking this project.
                        • robiniscool
                          • Jul 2010
                          • 299
                          #57
                          oh ya..
                          nope but you can mount a 5spd flywheel in a 6speed
                          • MonkeyMadness
                            • 3251
                            #58
                            But why i guess is what I'm asking..?
                            Is it just cause of the difference in the flywheel/crank trigger wheel?
                            • JGood
                              • Jan 2004
                              • 7959
                              #59
                              The input shaft of the 5 speed zf trans is not the same as the 6 speed, the 6 speed clutch disc won't fit onto the 5 speed input shaft. The 5 spd ZF is the same as the one used in the 328/m3, just with the v8 bellhousing. That's why we use 328 clutch kits.
                              e30 restoration and V8 swap
                              24 Hours of Lemons e30 build
                              • MonkeyMadness
                                • 3251
                                #60
                                Oh.. Awesome!
