302 carb, fuel?
  • knuklehead92
    • Aug 2011
    • 732
    302 carb, fuel?
    i have been researching and havent found a clear answer. When running 302 carb in an e30. what do i do for fuel????? delete electric stock e30 pump and go mechnical? can anyone chime in please.. I have a 87 325is so it has dual fuel pumps one in tank and inline...
    I am about to pick up a roller block this saturday and start a build thread soon 347 stroker :firehop:
    Trust me it stock :yawn:
  • dashboardmonkey
    FUCK YOUR WAFFLES
    • Jun 2008
    • 6158
    I think holley sells an afpr to suit your needs.
    Summit.com iirc
    -Andy
    • shEck3lls0
      • Jan 2011
      • 1154
      Funfgang is running carbed. I helped him build his car. But at first he ran a fpr that went bad because it was a single inlet/outlet and couldnt hold the 30+psi from the stock fuel pump. Now he runs an adjustable holley fpr that has a return line so the pressure doesnt fatigue it. Been working great. 6-7 psi should be good to suit your needs. but make sure to get something adjustable.
      1989 Alpine 325is 2dr m50 swapped
      Build Thread:
      Current ongoing build. Check it out!
      1991 318is 4dr rallycross
      Rallycross Build Thread.
      1991 Alpine 318is coupe - sold
      • FunfGan
        • Jan 2011
        • 4958
        Yep, Adjustable FPR with in/ out/ return lines and you'll be set.
        Go here be happy!
        Ratchet Garage e30 V8 build.
        • eurotrash
          • May 2007
          • 768
          You'll need the fpr (holley, mallory, aeromotive ect) and dont forget the fuelpump blockoff plate if your motor has a pump already. Pretty sure holley blue pumps come with an adj fpr. Its like $110 and a fpr runs like $80 to 100 anyways.
          Or just run the fuel lines to the mechanical pump and pull the fuel pump fuse. It shouldnt have a problem drawing thru.
