M60 check your oil pump bolts
  • mark///m3
    • Oct 2007
    • 287
    Sorry for the caps title but I thought this was pretty important and hopefully it can be stickyed for future swappers. I decided to check the oil pump bolts on my m60 and make sure they were still torqued. Well I pulled the oil pan and found a nice surprise....
    My chain is also way out of adjustment probably from the oil pump flopping around for so long. I'm glad I checked this otherwise my engine would have been toast slightly after all my hard work.
    ___________________
    Mark
  • MonkeyMadness
    • 3251
    Damn!
    • JGood
      • Jan 2004
      • 7959
      That's common on m60's, all of mine were loose as well. It's good to pull the lower pan once a year and check them.
      e30 restoration and V8 swap
      24 Hours of Lemons e30 build
      • mark///m3
        • Oct 2007
        • 287
        Yeah I read about it that's why I did it but I never saw it mentioned here.
        ___________________
        Mark
        • mark///m3
          • Oct 2007
          • 287
          Justin
          Have you checked your x5? I'm thinking about pulling my pan on mine next oil service just for good measures....
          ___________________
          Mark
          • JGood
            • Jan 2004
            • 7959
            Originally posted by mark///m3
            Justin
            I haven't. From what I understand, this was only an issue for engines made prior to 1998 (so all m60's and only the early m62's). Probably wouldn't hurt to check though!
            • E30SPDFRK
              • 5715
              Mine were loose on my 2001 540, I'd check them if I were you.
              Byron
              Leichtbau
              • JGood
                • Jan 2004
                • 7959
                Yikes. Thanks for the heads up.
                • bongo78
                  • Jul 2012
                  • 65
                  Ouch will have to check mine that I just started driving (94' M60). Is the oil pump fully accessible just from the bottom pan?
                  • mark///m3
                    • Oct 2007
                    • 287
                    Yes it is, there are a million bolts holding the pan on so get some sort of power/ air tool handy
                    ___________________
                    Mark
                    • bongo78
                      • Jul 2012
                      • 65
                      Thank you man for the heads up :eeek:, you saved me $$$ in future damages. Three bolts in my oil pan aswell :(, also all the bolts on the oil pump were going down as well :( . Still wondering how one of the bolts came to the pan and not the engine, on the second picture behind that plastic cover was his original place . Engine in question is M60B40 '94.
