Tempting!!! (V8 parts content)
  • MattAvino
    • Jan 2011
    • 2147
    Thoughts? (craigslist)
    BMW V8 + 6 speed /// M62TUB44 Getrag 420G - $2000
    Selling a M62TUB44 and Getrag 420G 6 speed manual transmission. Originally came in my 2001 BMW 540i Sport (E39). Great for someone looking to swap into a project car, do an auto to manual swap, or just looking for a replacement drivetrain.
    roughly 100,000 miles on the engine and transmission.
    I am told the previous owner changed the clutch and flywheel for new units around 25K ago.
    No leaks or damage of any sort. However, the VANOS makes slight noise when warmed up. Does not affect the performance of the engine.
    Comes will all front end accessories.
    Power steering pump is 1 year old.
    Expensive water-cooled alternator is 10 months old.
    Water pump is 10 months old.
    I did the valley pan overhaul about 8 months ago, which included replacement of the following parts with OEM:
    valley pan cover and gasket
    intake manifold gaskets (x4)
    throttle body gasket
    CCV (rear manifold cover, along with new gasket)
    water pump replaced with metal impeller type
    2 new serpentine belts
    water manifold gaskets (rear of block)
    vent pipe underneath the manifold
    both water tubes under the manifold, along with new O-rings
    E30 buildy things
    http://www.r3vlimited.com/board/showthread.php?t=195286
  • MonkeyMadness
    • 3251
    Do it!
    • E30SPDFRK
      • 5716
      Stay far away from m62tu's, one of the shittiest BMW V8's they ever made. What you want is an m62 from either 97 or 98 without vanos.
      Byron
      Leichtbau
      • MattAvino
        • Jan 2011
        • 2147
        You're right, but the tranny and block would be the keepers.
        E30 buildy things
        • MonkeyMadness
          • 3251
          Fuck it, your not the first to use it and your not going to be the last.
          Build it and enjoy it...
          • Vtec?lol
            • Dec 2009
            • 3278
            if you have the time to deal with water cooled alternators, vanos rattle (it's very embarrassing at start up) then go for it.
            • MattAvino
              • Jan 2011
              • 2147
              The motor got sold. But everything else is still available.
              E30 buildy things
              • MonkeyMadness
                • 3251
                If this is some thing you really want to do. I would start hording parts now.
                First thing i got was the motor and have been looking for part sense.
                Good luck.
                • CoreyZ
                  • 384
                  Well, see what he wants for the trans. Honestly I wouldn't pay over a grand for it - I know someone that sells M5 420Gs for $800. If you want to do the M6X frankenmotor, pm me. I have a B44 block.
                  I still have the whole M62b44 NV in pieces, so if you want the whole thing, let me know.
                  • Garageaholic
                    Freestyle Fabricator
                    • Dec 2005
                    • 5204
                    6 speed makes the swap more more expensive and difficult, but definitely worth it for the wow factor.
                    Frank
                    Recent Rebranding!!
                    E30 SM62/S62
                    E30 M60 V8
                    E30 M30 Big 6!
                    Instagram.com/garageaholic
                    Youtube.com/garageaholic
                    • MattAvino
                      • Jan 2011
                      • 2147
                      Frank
                      Custom driveshaft?
                      What are the other main things that need to be done to incorporate the 6 speed?
                      E30 buildy things
                      • MattAvino
                        • Jan 2011
                        • 2147
                        Nevermind on that question. I looked at your thread again and, yeah, the 6spd looks like a PITA
                        E30 buildy things
                        • bmw325csi
                          • May 2007
                          • 4045
                          Originally posted by MonkeyMadness
                          Do it!
                          harry/harout
                          • Jonsku
                            • Oct 2004
                            • 566
                            Nothing special with the 6-speeder. You just need to modify the propshaft and shift linkage - piece of cake really.
                            M62 with VANOS is a great and silent engine, though most probably you would need to replace vanos units and whole timing end (which you should do with normal M60 swap as well)..
                            - E34 M5 (x 2) -
                            - E30 V8 Cabrio "Kylpyamme" -
                            - Alpina D10 Touring #33/94 -
                            - E46 318i Touring -
                            - Toyota Hiace 4wd -
                            • Etexise30
                              • Sep 2012
                              • 208
                              yo i really need DME and EWS how much if u still have it !!!! i cant crack my AUTO dme yet
