e30 "standard" V8 mounts... A question...
  • M3 euro ltw
    Site Sponsor
    • 259
    There is a wealth of experience in the forum, andi suspect someone may know the answer to this.
    In a standard M50 transplant, you guys know how to pick a specific driveshaft and rear tranny brace to fit the ZF e36 M3tranny, or Getrag 325 tranny.
    Does anyone know if the M60 with 5 speed will use the exact same spacing forward to rear using these common mounts....
    In other words, if you had a M50 engine with its five speed before going to a V8 using 300mm brackets, would you be able to retain shifter parts, DS, tranny mounts?
    Or...
    Do these common brackets move the tranny forward or rearword from that position?
    Trying to make the world a better place, 6 TB at a time.
    http://abloriginalparts.com/
  • robiniscool
    • Jul 2010
    • 299
    Had to shorten Shifter, used E36 m3 4 bolt driveshaft and e30 manual tranny brace
    • M3 euro ltw
      Site Sponsor
      • 259
      Thanks
      To be clear.... You shortened shifter compared to what prior gearbox, behind which engine?
      The stock crossmember you used was meant for m20 based getrag?
      • robiniscool
        • Jul 2010
        • 299
        5 speed from a 94 530i, m62b44 block (block size and mounts should be the same with all the m6x blocks) and yes it was a m20 tranny brace
        • Jonsku
          • Oct 2004
          • 566
          Yes they are, also S62 is very similar.
          - E34 M5 (x 2) -
          - E30 V8 Cabrio "Kylpyamme" -
          - Alpina D10 Touring #33/94 -
          - E46 318i Touring -
          - Toyota Hiace 4wd -
