College kid M60 E30 (ongoing build)
What master cylinders are you using? I missed some of the details. Can you share? I will be using a similar setup in my car. Also what flywheel did you end up using? I recall you were looking to resurface one?sigpic
Velocity Motor Works
1972 2002
1983 533is
1987 325is (Roxanne)
1988 M6
1989 M3
1989 325ix (Darth Maul)
Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...Comment
I used two Compact Remote Flange Mount Master Cylinders in 5/8" bore for the brakes, and 3/4" for the clutch, in combination with Garagistic's brake booster delete bracket. The write-up for that is located here.
For the flywheel setup, I went with an OEM replacement from Luk for the M60B30. Part # 21211223508.Last edited by MJCRO; 09-22-2013, 09:04 PM.Comment
Thanks for the quick response man!sigpic
1972 2002
1983 533is
1988 M6
1989 M3
Damn kid good job, I'm still miles away from turning mine over...
Excited to see the finish..https://www.forabodiesonly.com/mopar...re-irs.356333/
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.Comment
Update: September 3rd
On four wheels again!
Got my E36 steering rack and big guibo 325e driveshaft installed. No more bus-like steering! Still need to hang up the exhaust, bleed the clutch, mount my cooling system and finishing putting back the interior together. Getting things done as parts arrive in the mail.
The car is on Eibach Pro Kit lowering springs and Bilstein shocks for now but I'm in the process of getting coilovers. Also, I'll be doing a late model bumper swap in the upcoming weeks.
I plan to take a crap of load of high quality pics of the car after I get everything put back together so it can stand as a reference for other people, but here's some from today after rolling it out to clean the garage.
I love what you've done!! Any more sweet exhaust shots? What's your ecd for completion?Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Instagram.com/garageaholic
Youtube.com/garageaholicComment
Should be another few weeks, just waiting on suspension and other goodies to arrive in the mail. Your exhaust lines up great! Just need to play with the v-band clamps until I have it flush with manifold. What about you?Comment
Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Frank - you crazy, i love it!Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Damn Frank, you moved fast!
Ordered E39 525DTS mounts two nights ago like Garagistic recommended for their setup so I'll see how those work differently. These revshift ones have settled far too low and the pan started to touch the subframe.
Also, I have coilovers and an M-Tech 2 wheel coming next week. BTW anyone have a E30 blower fan speed switch for the HVAC? (part #61311381201). I need one on the cheap if anyone's got one, I can't find mine in the garage and I'm finishing putting the interior back together.Comment
