College kid M60 E30 (ongoing build)
It's a good I dea you got the pedals installed before you put the motor in. I recomend flushing the ABS and lines with fresh fluid and then bleeding the FACK out of the pedals. They are a pain in the ass to bleed. Hopefully you remembered to bench bleed first. Be prepared to take them out a few times to make proper adjustments
So how's this going? Are you driving yet? I'm tempted to follow in your footsteps with the pedal setup once I get back into this swap.sigpic
Velocity Motor Works
1972 2002
1983 533is
1987 325is (Roxanne)
1988 M6
1989 M3
1989 325ix (Darth Maul)
Gone: 1974 2002, 1984 318i , 1985 318i, 1988 325ix Sedan, 1988 325ix Coupe, 1991 318is, 1991 318i, 1994 525iT, 1995 325is, 1996 M3 Coupe, 1997 328is, 2001 325i, 2001 Z3 2.5i, 2001 330i, 2001 525iT, 2006 F-250 SD and more...Comment
Almost. The motor and transmission are seated in their final positions. I was just held up on updating this thread because of fuel lines that took a while to arrive from Germany. Just finished installing everything back together yesterday. Pictures up soon.Comment
Update: August 7th
The car is inching it's way towards the road. Still need to pick up a few more parts, but I'm pretty much at the point where I can slowly begin to put everything back together and fire her up.
Painted the engine and valve covers and did some required maintenance.
Motor sitting in the rear most position.
All new pre-bent fuel lines I waited over a month for. (Old ones were rusted through in some spots)
Shifter linkage cut to fit E30. (ZF 310Z)
Needed to purchase a manual transmission mount since the car was originally autotragic. (Bolts up perfectly, no modding required)
Mocked up FrankM's exhuast setup I got off of him a while back, no issues whatsoever.
Man that is inspiring! I'm going to do a s52 swap and I thought that was going to be tough lol. You have your hands full there!Comment
Oh damn, IT"S ALIVE!!
Where'd you get your new hard lines from?Click here to leave me feedback on our transactions. :pComment
Glad to hear its alive!Comment
1974.5 Jensen Healey : 2003 330i/5Comment
